How to replace your BMW battery!
I am driving with an 'unregistered' battery - '06 530i (N52, E60). I simply bought a new battery at BMW for $240. I replaced the battery myself. I will update y'all if I run in to any issues in the future.
Hello
true... see the following doc coming from BMW TIS : http://dl.dropbox.com/u/6738336/SI%2...l%20series.pdf
Matt
Matt
My Ride: 2004 545i Sport, Sound, Cold weather package, Steptronic, Logic 7, Sunshades, CD changer in glove. Alpine White, with light tan Dakota leather, Good seats. Just out of warranty.
Previous: 1997 528i. Sold '09.
1981 320i. Sold '89.
I'm sorry if this has been done a lot. I'm also new here. I came here because I did buy a battery for my 545i 2004 last Oct. I had error messages for months. I had my freelance BMW mechanics buy the new battery and install it. I see now this is too much for guys that don't have access to BMW website for repairs on these newer electronic cars.
I did take it to BMW and they gave me a bill for $2100. I thought there was a leak somewhere, and whatever the error messages were.
Then I was getting more messages. Back into the shop. New battery, the BMW battery. and the "re-programing" of said battery. My old battery is in the trunk. I was too afraid to work outside the box. That cost me $800.
iDrive or computer is still funky. I don't drive my car a lot. It's a 2004 with 46,000 miles on it.
I want to get a aux jack for my iPod but I don't want to screw with the goodies of this car if it is going to continue to bleed me dry. In 6 weeks I spent $4200.00.
So is not driving a lot a big problem? Will this continue?
How many miles is enough?
Thanks
Thanks
My Ride: 07 550i Titanium Silver, Black Dakota Leather, Steptronic, Sport, Premium, Nav, Sat. Radio, Logic 7, Comfort Access, Rear Sunshade.
Thanks
Thanks
My Ride: 2015 535D M Sport
So if it`s hype, why is the battery registration functions in Progman / ITSA/p and DIS?, I personally have a Varta 110ah battery I bought off ebay for £90 but I still took the steps to register it to the car with my own Progman / DIS setup.
My Ride: BMW 530D E60
Yup, +1 on battery registration. Bmw put it into their diagnostic software for good reason, i also replaced my battery this year with a 90Ah Varta unit and registered the unit.
Took this from another forum, but it explains it quite well...
"We have got to remember this coding/registering (BTW and indie's can do it, so not a dealer only option) is the first step towards the ED features and brake regeneration, etc. Energy management is definitely a step forward from E46/39 technology and it can't work efficiently if not given the starting parameters, (battery size, capacity, etc.), simply to prevent future unwanted side effects. Even changing an alternator can cause issues if not carrying the correct chip.
The energy management will trim energy demands to keep a 'start-up' capacity. Consumables like the heated rear screen, will not function if the battery won't support the demand, so we are now in a different game even for something like a simple battery.
The truth is, we have so many features/options now, which demand current, that a simple battery just isn't efficient and able to cope with the average use a car gets, without a management system.
It appears more manufacturers are heading this way, it seems Audi may have a simpler change for the battery, but I've read they still do benefit from a garage coding. The other issue is, some cars lose functions on disconnecting the battery, so re-initialisation of features has to be undertaken. The computer link up ensures all functions are working and loogged to the management system."
Gav
Gav
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Regarding the two types of battery fitted to the E60 i.e. sealed lead-acid (white in colour)or AGM (black in colour),I recall reading somewhere that after March 2007 the AGM was standard fitment.The AGM does not have the "magic eye" charge indicator but both types of battery have the vent tube fitted.I also found the following article where the answer is from a BMW Senior Technician :-
" Does replacement of the battery in a 2005 BMW 530i have to be done at a dealer?
Best Answer - Chosen by Voters
Hi,
Technically no it does not, however it would be preferable and I will explain why. Firstly, on your BMW the energy management system needs to be told that a new battery has been fitted. This is done by registering the replacement through the BMW diagnostic computer. Without getting too in depth this is important as to the charging characteristics etc.
Secondly there are two types of battery fitted to BMW's. The earlier standard Lead Acid battery (white casing) and the later AGM (Absorbent Glass Mat) in a black casing,
If you have the white casing type you could fit any battery of similar type without registering if you really wanted to avoid the dealer, although I would advise it best to get it registered for a prolonged battery life.
If you have the AGM type it is especially important that it is replaced like for like and the replacement is registered as explained above. If you fit an older type Lead Acid the battery will be overcooked and useless in no time at all.
I hope that helps,
Good luck, Pyth
Source(s):
I am a BMW Senior Technician "
Hi,
I hope that helps,
Good luck, Pyth
Source(s):
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
how do you register the battery in dis or sss
