How important are those underbody panels??
My Ride: 545i Sport
Engine: N62
I'd recommend to buy genuine BMW parts for these underbody panels. I bought a replacement (for #5) that was made of different material (plastic) and it got soft and sagged due to engine heat and was scrapping the road and barely hanging on three screws.
UNDERRIDE PROTECTION Genuine BMW part
Yes things have changed. More automobile manufacturers have copied BMW's streamlining of the under body flow via belly pans.
In an article published this year GM acknowledged the importance of under body panels in achieving excellent high speed aerodynamic performance in the Camaro ZL1.
I know you leave yours off, believing that you experience better cooling on your transmission. If that were true, piston engine aircraft engines would not have cowlings. Long ago (1920's) aircraft engineers discovered that covering the engine with a cowling to direct the airflow in an efficient stream dramatically improved cooling of the engine as opposed to leaving it hanging out in the air stream. Ninety years hasn't changed this principal of fluid dynamics.
11 years doesn't change the principals of physics or good aerodynamic design achieved from application of same.
![](https://5series.net/forums/public/style_emoticons/default/rolleyes.gif)
Yes, you should keep them on the car. As stated by others, they do several things. One important is improving air flow which then creates less turbulence. Sometimes you can hear and other times you may feel it. I am actually at a supplier since yesterday in Akron that make these type of panels. They are now producing the LWRT which is a light weight fiberglass breathable material. It doesn't hold any water and is a fraction of the weight. Maybe you can rivet a small metal sheet on your part then glass it?
My Ride: | 2010 535i x-drive | Monaco Blue Metallic | Cream Beige Dakota | 6 Spd Manual | Sport | Cold Weather | Premium | HUD | Navi | Logic 7 |
If I were you I would try any auto body shop that you know especially if you know somebody that works at the BMW autobody shop they can definitely hook you up with the used piece specific to your car
Also I would never buy that piece new, I'd rather attempt to fabricate that peace piece before buying a new one Rather paying them a premium for it. Hell it'd be cheaper to use a 3-D printer to print it out Instead of buying from the dealer
Vman33
03-14-2022 04:43 AM
brooklynbmw
09-16-2015 01:41 PM
umnitza
09-02-2015 11:28 AM
