How do you make the "service engine light soon" go out, withou
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
How do you make the "service engine light soon" go out myself, without paying a BMW Stealership their HIGH COST!!
Thanks in advance!!
Eddie aka Presley348
Thanks in advance!!
did you try removing and replacing the fuel filler cap? Some SES lights are due to improper seal around the gas filler cap.
My Ride: 07 550i black sapphire DPE s20 wheels powder coated satin bronze with gloss black lipLCI tails US version Black grilles (DIY)M5 Fender Grilles (DIY)M5 Umnitza RearCustom made Magnflow quad exhaustCarbon Fiber interior wrap (motorcepts)
You need a OBDII scanner tool to find out what is causing the light to come on and go from there. The Scanner tool can reset the light but depending on what the problem is it will most likely come right back on until u fix whatever is causing it to come on. Could be a bad o2 sensor, etc. Just go to a local autozone and they can do a Free Scan for u and tell you whats causing the light to come on. Maybe you could ask whoever does the scan if they could reset it to see if it comes back on as well.
Titanium Silver
Premium Package
Adaptive Xenon's
Michelin tires
Sprint Booster - V2
![Talking](https://5series.net/forums/images/icons/icon10.gif)
Thanks, and I am going to try autozone first!!
Eddie AKA Presley348
My Ride: 2006 530i
^^^ +1
but good luck finding a place that will reset it. autozone workers and most shops are instructed not to reset the light due to legal and safety precautions. then again when the autozone worker comes outside to check your car out, giving him a $20 tip might help your cause
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
^^^ +1
but good luck finding a place that will reset it. autozone workers and most shops are instructed not to reset the light due to legal and safety precautions. then again when the autozone worker comes outside to check your car out, giving him a $20 tip might help your cause![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
![](https://5series.net/forums/public/style_emoticons/default/wacko.gif)
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
My Ride: 545i sport
Don't bother resetting the light if the root problem has not been solved. Once the cause has been corrected, the light will clear itself after multiple restart/drive events. What this means is that if the gas cap was/is the problem and you replace or screw it on properly, the light will stay on for several days/restarts and you might think it had no effect.
So, get the code read, correct the problem(s). IMHO, the most common cause of the SES light is a vacuum leak related to the fuel tank system (yes, this also includes the gas cap). After that, it's the air pump which checks o2 sensor functionality/health. Next would be ignition coil related issues. Then, anyone's guess.
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up!
04 545i all the goodies INCLUDING HEADACHES!
