Hoping for silence...
Old 07-15-2005, 06:10 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Originally Posted by Edlee' date='Jul 15 2005, 08:04 AM
I have had this problem of rough idle and fluctuating rpm needle since the day I collected my ride.? It is a real diasppointment.? I have sent it in to the dealership many times but they are just unable to correct the problems.
I was under the impression that this is an Asian problem; the temperature here is quite high, but it seems not.? Actually, if you check all the threads and responses about this rough idling, jerky response and fluctuating rpm needle, the guys who experience these problems are those driving the 545, and it's supposed to be the top of the line E60.
[snapback]149386[/snapback]
Yes, I've seen that too. Some reported some sort of vanos or value adjustment as a fix, by my tech sees no problem. How much does you RPM fluctuate while idling?
Old 07-15-2005, 06:51 AM
Edlee's Avatar
Fluctuates approx 100 to 150 rpm. Gets really bad when I'm caught in heavy traffic.
My dealer did a valve adjustment for me a few weeks ago. Rough idling went away for awhile but has now returned.
Old 07-15-2005, 08:55 AM
E60COYOTE's Avatar
I'm hoping to get my door seals replaced soon. Parts are on back order...
JDN - I would like to hear more about your AC noise. I have been dealing with a high pitch whine coming from the engine compartment when the engine is reving from 1000 to 2000 rpm. It resonates into the passanger compartment at slow speeds (30-50 mph). It has been to the dealer 3 times for this, once they replaced the tensioner pulley and other bearings (supposedly). It seemed logical, but I still have the noise. I though it was the AC compresor from day one, but disconnect the power to the clutch so the compressor wouldn't spin and there was no difference.
Does this sound like the problem you had? if so, what exactly was replaced?
Old 07-15-2005, 09:44 AM
John W's Avatar
On the idle, mine feels rough, but the tach needle is stable. I'll complain next time I'm in, but it seems like everyone here's saying the needle's bouncing with the rough idle.
On the fan sound, when it's hotter outside in the Summer, like it is now, the aux/cooling fan is running at high speed, and definitely is louder on shutdown. It's 100% consistent for me depending on the temperature. Above 90 degrees, the fan's running pretty much full time, under that, it's not. I think it's just normal operation, and the E39 was the same. We had those really loud jet turbine-sounding fans that ran in the Summer.
Old 07-15-2005, 10:00 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
Originally Posted by John W' date='Jul 15 2005, 11:44 AM
On the idle, mine feels rough, but the tach needle is stable.? I'll complain next time I'm in, but it seems like everyone here's saying the needle's bouncing with the rough idle.
On the fan sound, when it's hotter outside in the Summer, like it is now, the aux/cooling fan is running at high speed, and definitely is louder on shutdown.? It's 100% consistent for me depending on the temperature. Above 90 degrees, the fan's running pretty much full time, under that, it's not.? I think it's just normal operation, and the E39 was the same.? We had those really loud jet turbine-sounding fans that ran in the Summer.
[snapback]149443[/snapback]
Thanks John, sounds like the Aux fan is the source and is normal. Guess I had not noticed it last summer. Thanks for the info. As for the idle, yes mine seems to be more instrument related than a real rough idle that can be felt.
dmahon
12-08-2020 09:53 PM
fifthofjac
08-30-2015 07:08 PM
kvtire
08-02-2015 09:03 AM
juji126
07-23-2015 10:59 AM
jinsta
07-22-2015 08:29 AM
Quick Reply: Hoping for silence...
