Hong Kong E60 sub-Forum
#6661
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Originally Posted by ricky1329' post='706081' date='Oct 29 2008, 04:08 AM
I checked and found PIAA actually not a build-in resistor, they have a extra connector with tube. which that tube is we talking about the load resistor. But they pack in good look only.
All claim have build in led are suck also, they also use the connector wiring to trick.
Power (W) = Voltage (v) x Current (A) , Voltage (V) = Current (A) x Resistance (ohm)
For Angle eye,
non-xenon version use 12V, 5W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 70 ohm resistor
xenon version use 12V, 10W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 20 ohm resistor
License plate use 12V, 5W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 70 ohm resistor
Mean the resistor value depend on which led being use.
May be I said too much, I will buy some 20 ohm; 30 ohm; 50 ohm for try and error.
For Angle eye,
Glad to have a electronic genius in here to help us out
#6662
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
#6663
Originally Posted by ricky1329' post='706285' date='Oct 29 2008, 09:21 AM
Brought the things back and will start DIY soon.
Thanks for that buddy
#6664
My Ride: 530i
Originally Posted by keith84_uk' post='706287' date='Oct 29 2008, 05:24 PM
Nice! Cant wait for Friday!
before install resistor - light on but have error code
After install resistor - light still on but error code gone.
Now use the cheap cheap ceramic resistor for run-in test. If still haven't error code, will change to aluminium resistor later-on
#6665
My Ride: 2004 BMW 520i E60 in Amethyst Gray
Originally Posted by pinguhk' post='706024' date='Oct 29 2008, 11:31 AM
cool you going to get it.
what about the peddle shift Streeting wheel, have you got it?
#6666
My Ride: Mini Cooper
Originally Posted by ricky1329' post='706285' date='Oct 29 2008, 05:21 PM
#6667
Originally Posted by deriffic' post='706392' date='Oct 29 2008, 09:49 PM
No, not yet. But just ask ahead so that I know how to approach. Hopefully I will find the steering wheel soon.
#6668
You must get them keith
the plate is 99% close to what it looks like with led
#6669
Originally Posted by pinguhk' post='706450' date='Oct 29 2008, 02:58 PM
here you go was at sing fai to night and ricky install the led and look good.
Meaning to get the resistor before, but being a electric idiot, i have no idea what to get at all haahaa
Thanks again Ricky, and you finally managed to take the bulbs out
#6670
My Ride: 530i
Till tonight still in error free, will keep on update about the result.
