Hong Kong E60 sub-Forum
Old 10-28-2008, 08:04 AM
  #6651
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Originally Posted by ricky1329' post='705405' date='Oct 28 2008, 03:57 PM
In Sham Shui Po should have, tomorrow may go around and shop
Are you able to get two for me if you go there tmr? (For the License plate)
Old 10-28-2008, 08:22 AM
  #6652
deriffic's Avatar
My Ride: 2004 BMW 520i E60 in Amethyst Gray
Originally Posted by keith84_uk' post='705395' date='Oct 28 2008, 11:48 PM
Its around 300USD + Shipping
OK, if you know the seller's name & e-mail, please PM me or post it here. Thanks a lot.
Old 10-28-2008, 08:36 AM
  #6653
keith84_uk's Avatar
Contact member "my530i" for more details, goodluck with ur purchasing
Old 10-28-2008, 06:28 PM
  #6654
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Did your license plate LED still keeping on post the Error Code ?
No problem and can try to install in this Friday if I can find them.
Old 10-28-2008, 07:29 PM
  #6655
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by ricky1329' post='705339' date='Oct 28 2008, 10:59 PM
pinguhk
License plate LED with resistor then error-code free
Attachment 62942
wow that is a big 1.
I have seen some e90 guys get the LED which has built in 1s and work
Old 10-28-2008, 07:31 PM
  #6656
pinguhk's Avatar
cool you going to get it.
what about the peddle shift Streeting wheel, have you got it?
Old 10-28-2008, 07:32 PM
  #6657
pinguhk's Avatar
They should have them, they got every thing at SSP
Old 10-28-2008, 07:46 PM
  #6658
keith84_uk's Avatar
I bought the LED with build-in resistor from one of the member in here before (From US), but one of them has gone in only 2 weeks, so i put my blue tinted bulbs back in.
But they are 100xtimes less bright as the LED, the PIAA LED with built-in resistor cost about 700HKD!!, so thats the reason why i give it a miss.
I appreciated if you can get them but if you are not going today, let me know what should i look for, anyway, speak to you on friday buddy
Old 10-28-2008, 08:08 PM
  #6659
ricky1329's Avatar
I checked and found PIAA actually not a build-in resistor, they have a extra connector with tube. which that tube is we talking about the load resistor. But they pack in good look only.
All claim have build in led are suck also, they also use the connector wiring to trick.
Power (W) = Voltage (v) x Current (A) , Voltage (V) = Current (A) x Resistance (ohm)
For Angle eye,
non-xenon version use 12V, 5W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 70 ohm resistor
xenon version use 12V, 10W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 20 ohm resistor
License plate use 12V, 5W bulb, Then means draw 0.42A current, if replaced by led which assume draw 0.25A current, then need 70 ohm resistor
Mean the resistor value depend on which led being use.
May be I said too much, I will buy some 20 ohm; 30 ohm; 50 ohm for try and error.
Old 10-28-2008, 08:17 PM
  #6660
pinguhk's Avatar
For Angle eye,
wow abit too much info for some ppl
hope it it work
Quick Reply: Hong Kong E60 sub-Forum
