High Mileage N62?
Old Aug 7, 2012 | 10:49 AM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
The n62b44 and n62b48 are 2 different motors. I suspect that BMW learned how to resolve the various gasket leak issues prior to the transition from the 4.4 to 4.8 block.
Old Aug 7, 2012 | 12:36 PM
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
Yes, I believe that's what happened, luckily for the 550i people. I did the coolant pipe and the whole round of oil leaks on my 545i at about 110k. It's at 170k now, and nothing currently leaks. I'm expecting it all to start again in a year or two, and I'll just bite the bullet and do it all again. Until then, I'll just glance back at the garage floor when I drive out, and see what color puddles I'm leaving.
Old Aug 7, 2012 | 03:04 PM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
Originally Posted by 545iMike
Do the oil cooler lines plug into the alternator bracket? Just curious. That seal behind that bracket has to be for something. Could you snap a couple pictures of the mounting for the oil cooler itself once its back together. Just wondering where and how it mounts. I had mine apart recently and saw your post. I had a look at mine (545) and was trying to figure out where the oil cooler would mount. In front or rad, behind, etc.....
If you look at the pic above, Right in front of the engine support arm are 2 holes. The oil cooler lines contain a thermostat on the end that plugs directly into these holes as one piece. It has 2 M6 screws that keep it in place. The other ends plug into the top and bottom of fan shroud/oil cooler itself.
I believe upgrading to this would solve a majority of your leak problems, long term.
Old Aug 7, 2012 | 03:10 PM
Originally Posted by Blackwolffm
Would it be risky to do a tranny oil change. Or should I pull the trigger now?
BMW lifetime fluid is considered to be 100k miles. Many discussions on this topic. I have not had any adverse effects doing a drain and fill. I would not recommend a flush ever. I do know that the ZF Lifeguard6 fluid is incredible stuff. Very slick, thick, and bonds to parts like crazy. I think if you kept it OEM and spent the extra money on the real fluid instead of Pentosin ATF1 (which is also good for many applications), you would be just fine. I would recommend under those guidelines.
Old Aug 7, 2012 | 03:19 PM
AchtungE60's Avatar
My Ride: E60 530i
Pentosin ATF +1 is an OEM fluid and it is real fluid buddy. I think it was you said you work on Bimmers on the side right? Then you should know that.
I didn't reply to you because this isn't your thread and also because I have no idea what car you drive, what your tranny is, how many miles it has on it and so forth and so on.......
Old Aug 7, 2012 | 04:11 PM
dolfan13's Avatar
Looked like to me Gulf countries?And South Africa 545i came standard with engine oil cooler.My link My linkFirst link to hoses second link to alternator bracket for cooler cars.Would like to here from south Africa to see if they have had as many oil leak problems.
Old Aug 7, 2012 | 04:17 PM
phlfly's Avatar
My Ride: 07' BMW 550i
Interesting......
Vman33
Mar 14, 2022 04:43 AM
andymax
May 20, 2018 11:32 AM
bestofthebest
Mar 28, 2016 02:47 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
LILBZ3
Sep 27, 2015 08:06 PM
