High drain battery message pop up
Old 03-24-2013, 06:54 AM
  #21
tonyb635's Avatar
If you are still under warranty you should be able to get the battery replaced for free. Most have in this case. If you are not and or the detect the add amp etc, the cost to replace your battery at the dealer is about 650.00. My guess it would be the same as they quoted me on my 08 535. If you have to replace it at your cost go to Autozone they have a seven year warranty battery and they will install it for you. Five years 100% replaced and the last two are prorated. The dealer battery is only covered for two years and would like kill your wallet, go figure... I left my trunk open, nothing else on recently for a couple hours. When I got in the car the clock was at - - - - and I had the battery drain message only in the cluster area which turned off when I started the car. I've never had it in the iDrive screen.
Old 03-25-2013, 05:25 AM
  #22
vk535i's Avatar
My Ride: 2010 535i, Sport, Nav, Platinum Gray, Blk interior
What I heard the warranty not cover for the battery. The way BMW design the electronic so sensitive, Just a bit hick-up, iDrive popup the message warning that really annoying me.
If you get new battery from autozone to install, then do you have to take the car to dealer for initiallized the new battery was installed?
Old 03-25-2013, 12:33 PM
  #23
H F
H F's Avatar
My Ride: 2005 545
If your still under the original warranty,, it is a warranty item and the dealer will replace it.. Been there done that one,,,
Old 04-01-2013, 05:04 AM
  #24
vk535i's Avatar
My original warranty will be ended by Nov. this year. Hopefully the battery die before warranty ended so I can have them replace new one for free LOL
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
patallen
05-30-2015 01:06 AM
Doctor Diesel
06-07-2004 02:20 AM
08-12-2003 11:41 AM
Quick Reply: High drain battery message pop up
