High drain battery message pop up
My Ride: 2010 535i, Sport, Nav, Platinum Gray, Blk interior
Hi all,
Today I got the "High battery drain" message on my car. About one week ago I have the JL amp and a 2.2 farad installed for the sub that is only the electronics were added on but I did not have any high battery drain msg for the whole last week until today. Let said if the Amp drain so much power and If I disconnect the power to the Amp, will the high drain msg go away or I have to take the car to dealer for reset?
Buy a battery charger and charge the battery - often.
You probably aren't driving for long distances. Driving short distances won't charge the battery fully, especially with the additional load.
I had additional load for like a week, no msg show until today bro. If the battery fully charge, will the msg go away or I have to take the car to dealer for reset the msg?
Yes, that message should go away when the battery is fully charged.
I see, from my home to work place about 9miles one way. Maybe it's not enough time to fully charge the battery? What charger should you recommend? I found one on Amazon with a lot good reviews ( )
My Ride: 2014 535 Alpine White
If you play music in your car without the car running it will drain the battery very fast. I get that message if i play music without the car running and i have the L7 system. I just start the car and set the clock and drive it. Message goes away once the battery is back to normal. You should look into installing a second battery for your amp so it doesnt put to much strain on your current battery.
I have only one Amp ( JL 500/1 ) should not take that much power. Second battery needed when running more thang 3 Amps or so.
My Ride: 2008 535i2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim
I see, from my home to work place about 9miles one way. Maybe it's not enough time to fully charge the battery? What charger should you recommend? I found one on Amazon with a lot good reviews ( Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger : Amazon.com : Automotive )
My Ride: 2005 545
Hi all,
