High Battery Drain - DEALER CAN'T FIND CAUSE!
I've had a high battery drain warning come up twice on my car, and it's on my list of things for the dealer to check out when I bring my car in next. I do have a trickle charger which I use overnight every couple of months, and this seems to help.
I also came across this thread a few months back -- perhaps this helps?
https://5series.net/forums/topic/923...&#entry1091657
Good luck!
Good luck!
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
Leaving the fob in will activate the first stage of the ignition which will wear down the battery. If you can get it to turn off, the warning buzzer and dash light will beep to tell you the fob is in the ignition. At least thats what my car does. To stop the lock/unlock cycle I leave the fob in the garage when I wash the car.
My Ride: G30 M550i
Model Year: 2018
Guys, the CAS module does not refer to "Comfort Access". CAS stands for "Car Access System" and it handles tons of stuff related to the car and is present on all E60s, whether the car has Comfort Access or not.
Everything you need to know about what the CAS module does is in the following thread:
https://5series.net/forums/topic/378...post__p__46572
As far as what's wrong with ECF's car, it's clearly something either preventing the car from going to sleep or something repeatedly waking the car up at some interval. My guess is the latter, not the former. If you park the car and come back 20 minutes later and look in the window (don't touch the car) is the car asleep? If it is, try coming back and checking on it every 10 minutes or so to see if it's still asleep. I realize this is a pain in the ass but it might be worth trying it for as long as you can (over many hours, if possible) to see if the car is waking up.
Were there any tell tale signs that the comfort access handle module was at fault? I had my electrical system go dead last week and the dealer determined the ignition was "left on". Additional diagnosis is required as I told them I lock the car each evening (with CA) and NEVER leave the key fob in the car.
I drive approx 40-200/miles per day so my driving pattern is not at fault.
One interesting note is that 2-3 times before the car went dead I found the driver's door unlocked in the morning. So your post about the Comfort Access Door module has peaked my curiosity!
The dealer will continue the investigation when I return the car to them next week.
I had the same problem, that was diagnosed as a bad comfort access handle module.
My Ride: E60 M5, F85 X5M
If that was at fault, and thanks Rudy for the informative pdf's, I suspect that may have permitted my car to think or tell the ignition it should be left on and subsequently drain the battery!
Well I tried what Rudy suggested by checking on the car periodically and didn't see or hear anything. Just took my car back to the dealer today for the fifth time. Having them check comfort access door handles. I have a feeling they're going to reprogram my car as well. What a pain.
Since I'm not the original owner (bought it used back in early 2007), am I SOL on trying to lemon this car? I'm more curious than anything else since I love this car and have put so much time and energy into it that I can't imagine getting rid of it this way.
My Ride: 2013 550i M Sport 6MT Alpine White, 2013 X5 50i M Sport Alpine White
