Help with what the dealer/CPO warranty will cover and wont.
My Ride: E60
Engine: N54
I have an appointment with a dealer to have a the iDrive 60k vehicle check and few small problems I?ve had since I got my car in December. What are they going to give me grief over?
1. Ashtray door does not close all the way
2. A/C smells like mold/mildew at startup
3. Brakes griding/squeeling at slow speeds
4. Power window anti-trap function alert
5. Wood dash panel under iDrive screen middle-left vent loose
Are the service requirements countdowns or mileage intervals? I swear these mileages below have never changed! iDrive shows:
Engine Oil: 7000
Spark Plugs: 40000
Microfilter: 90000
Front Brakes: 24000
Rear Brakes: 28000
Engine Oil: 7000
Spark Plugs: 40000
Microfilter: 90000
Front Brakes: 24000
Rear Brakes: 28000
My Ride: 2007 525i (not LCI) - Alpine white, M sport package, Comfort seats, Logic 7, Bluetooth, Xenon adaptive headlights, PDC, sunroof, A/C with extended features, etc.
for the A/C smell, just turn your heat on full blast for 10 mins and it should go away...
Engine Oil: 7000
Spark Plugs: 40000
Microfilter: 90000
Front Brakes: 24000
Rear Brakes: 28000
Engine Oil: 7000
Spark Plugs: 40000
Microfilter: 90000
Front Brakes: 24000
Rear Brakes: 28000
just got mine done.iam actually picking it up tomorow.ashtray samething as your they replaced.rear vent broke and replaced,i even had a dash crack and replaced it.
My Ride: E60
Engine: N54
The dealer states they need a 2 hours of labor to reprogram the car because of the Power window anti-trap function alert NOT covered under the CPO warranty. I did however just have a full reprogram for the Aux Input (where I can see the FM station names too) a few months back at another dealer. Can one update trigger another problem?
A complete computer reprogram is needed at $254.20! What is different about this software vs. what was loaded 60 days ago?
Dash panel not covered but it only needs a little metal piece to pop it back in. They want to order the whole panel!?! Not needed, suggestions?
My Ride: E60
Engine: N54
Originally Posted by TurboChris' post='573122' date='May 2 2008, 02:53 PM
Sounds like BS to me.....maybe you need another dealer?
I then had him print SIB SI B 61 20 06, 'rear window fails to initialize'. from OCTOBER 2006.
The situation, cause, and procedure is to 'update software' in the KBM (Body Base Module).
Is the KBM the same thing as the software update done to activate the new aux input 60 days ago?
I'm really a dummy for doing this and I want my $254.20 back.
srogers535x
08-05-2015 08:48 AM
Kbc
07-27-2015 05:51 PM
