Help water in car drivers side/back only
My Ride: BMW 550I BLK
Engine: N62
I just wondering if anyone knows or has had water in the car but only on the driver's side floor and the floor behind the driver. I also looked in the trunk under the spare and found a Lil water then my TPM flashed as malfunction and electrical malfunction. I disconnected the white box in the trunk and didn't see water but i tossed it in rice anyway. Can anyone shed some light on this
Check your rear sunroof drains. Exit in the rear wheel well, above the wheel well plastic liner.
Also check for water inside your doors on that side of car. Water will fill the cavity and overflow behind the door cards and the vapor barrier. Open and close doors vigorsaly and listen for water sloshing around. If present, with door open, run your fingers along the outside door gasket. Dirt collects there restricting the flow of water out of the drain holes just under the door gasket, across the bottom of the door.
After all we just went through a hurricane here on the east coast of NE Florida. Wind blown water at hurricane strength can allow water to show up in all sort of areas...
Engine: N62
I'm gonna head out to try this. I went to a car wash to vac as water as possible. When I go him and parked back so the car slipped in thw from the carpet got wet again not soaked this time but noticeable.
Jet blk 2007 550i non sport
Jacksonville Forida
Jacksonville Forida
mvvette97
04-04-2016 10:35 AM
Paul Lofthouse
03-06-2016 09:12 AM
bmwmonkey
01-26-2016 03:52 PM
