Help with knock when steering!
Hey guys! When I turn my steering wheel fast to the right while the car is moving i hear a hard knock from the front left wheel area...it is like the wheel is hitting something... Any ideas what it could be? suspension? Tires look ok and steering otherwise feels normal... I hope it is something covered under the CPO warranty...
Car is a 2005 545i
Car is a 2005 545i
well i took it to the stealership and they just called me and said it was the subframe that needs to be replaced!! And it is covered by the CPO. I do not even want to know how much it would have been without the CPO warranty.
WTF?! how can the whole subframe fail? Do you think I will have any issues after it is replaced? will everything feel like factory again?
Thansks!
Thansks!
Well it is made of aluminum. Most likely it had a bad weld or stress crack. I holds the lower suspension, rack and engine. It bolts in so no big deal just could be a lot of labor.
My Ride: 2006 BMW 550i
