Help ID'ing engine part
Old Dec 12, 2012 | 02:53 PM
felixakinyemi's Avatar
Default Help ID'ing engine part
If you look at the attached picture, I was looking through my engine today and noticed the highlighted area was lose.
I have 2 questions.
1) Can this affect the engine performance in anyway
2) Can anyone help me name the part and if possible a part number as well.
I'm trying to self diagnose the lack of power my engine has been experiencing.
Thanks.
Old Dec 12, 2012 | 03:17 PM
pjinca's Avatar
Try realoem.com, just put in the car you have, the model, build date and then look at the engine schematics
Old Dec 14, 2012 | 02:57 AM
buddy's Avatar
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
Do or did you have a coolant leak also the filler box looks like it could use some tlc
Old Dec 14, 2012 | 04:46 AM
Yeah had a little problem trying a DIY. I'm just wondering if that lose part affects performance of the car.
Old Dec 14, 2012 | 05:08 AM
Stephen Max's Avatar
My Ride: 2004 545i Sport 1998 M3
I believe that is the hose coming from the secondary air (not to be confused with second derriere) pump. It attaches to the secondary air check valve, the round thingy. The secondary air system only operates for about 45 seconds at startup. If the check valve is stuck open, fresh air may leak into the exhaust and a false lean condition will be read by the O2 sensors. The ecu will compensate by adding fuel and the engine will run rich.
Old Dec 14, 2012 | 06:49 PM
Can that cause a missfire?
Kasmo
Jun 27, 2024 06:02 AM
gergnang
Feb 2, 2021 07:29 AM
2004_545i
Apr 8, 2015 04:01 AM
rkilpa
Mar 4, 2015 09:10 PM
