HELP with front turn signal
I was replacing my front turn signals today with white LED. The left side I forced the new bulb in and now its stuck. The right side is perfectly fine and it worked great. I CANT GET THE other turn signal out though. Its stuck. I am moving the "slider" out and but its stuck and I have the headlight partially off.
ANY TIPS?
ANY TIPS?
Yup - tape a piece of smaller hose [like a piece of heater or vacuum hose] to the larger hose of a shop-vac and fish around until you can get the bulb sucked up. IF you want to avoid having the bulb totally sucked into the shop vac use a small piece of women's panythose (it will act like a filter) over the end of the vacuum's hose.
Well it wouldnt come out. I guess I have to remove the headlight and I am going out of town tonight (Coming back tomorrow) taking the E60 LOL. Who needs front turn signals anyway . But in all seriousness our cars have sidemarkers and they are blinking twice as fast so not much of a problem.
I am pretty sure the original bulb holder is messed up because its still getting stuck I tried with the old bulb. The old bulb blinks but its loose so it stops after a while. I tried again and it did not blink at all. So I might need a new one of that. The problem is the new LED bulb is kind of big so its hard for it to get out of the small little hole which it fell in. After I remove the headlight its going to be easy to "dance" with it and it should fall right out LOL.
I might just visit John at his shop and have him install my angles and get that annoying bulb out. Either way lol I hope it gets resolved soon.
My Ride: BMW E60
Model Year: 2016
And I would highly recommend fixing the turn signal first before you take it on a trip. Defective turn signal can get you a ticket (if your local enforcement cares).
