Help with codes
#21
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Correction depends on how expensive your tool is and it has to be bidirectional. Any lower-end will not FA code a BMW. If you're trying to code it out it's best to buy used at a low price and program it to your VIN. It takes the same amount of time to do just have to spend $30 or less for the part. Now that I think of it I'm sure it's plug-and-play.
#23
#24
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by donpb
Clean the connector with electrical contact cleaner before replacing the module.
#25
My Ride: 2007 525xi
#26
Model Year: 05 530i
Engine: 3.0 M54
What are they in the connector? The module is missing pins. Once you get a replacement problem is solved. It's an easy fix especially if the goal is to get everything working like you wanted to otherwise what's the point of doing anything if the car is driving with no issues.
#27
My Ride: 2007 525xi
