Help! Car wouldn't start
Old Aug 19, 2015 | 07:39 PM
  #21
Gee_115's Avatar
My Ride: 07 550i Sports Package
Originally Posted by kcrokin
Shit, so I was on my lunch break, stopped at a light when all of the sudden my car started shaking and my screen (navi) said that there is a transmission issue. The car could barely move.
Also on the dash screen there is a car on a lift.
I pulled off to the side. Turned the car off, tried to turn it on repeatedly but it would not start. It finally turned on and the transmission warning was off and it drive fine.
I am working on getting pics uploaded.
Definitely battery issue, my car exhibited these symptoms (and a lot more) a few years ago, everything was ok after I replaced the battery. At least have the battery checked.
Old Aug 20, 2015 | 03:19 AM
  #22
kcrokin's Avatar
My Ride: 550i M Sport
thnx, ill give them the heads up. i appreciate it.
Old Aug 20, 2015 | 05:16 AM
  #23
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Also the car on the lift is a message to have your car serviced that can be reset in the iDrive. I would also have the fluid changed in the transmission. The other messages might be pointing to the battery going bad. Start with a battery check/change and go from there. You are over the point of have the trans fluid changed so I would do it.
Old Aug 20, 2015 | 05:42 AM
  #24
kcrokin's Avatar
Default Help! Car wouldn't start
So I just brought it into the dealer, they said it has a brand new battery and they are going to run a diag. I'll keep you posted. Thanks again.
Old Aug 20, 2015 | 01:28 PM
  #25
kcrokin's Avatar
They said that they tried to run a diag but the computer on the car was not communicating so they did a "hard restart" on it. Anyone have any idea what that is? Seems to be running fine now.
Old Aug 20, 2015 | 03:42 PM
  #26
A hard reset is setting something back to factory default. The dealership reset it to when it drove out the factory.
Old Aug 20, 2015 | 07:42 PM
  #27
kcrokin's Avatar
Got it, thnx!
Old Sep 2, 2015 | 08:45 AM
  #28
kcrokin's Avatar
This problem has happened all over again. I was sitting at a light RPM's went down to 0. Had to hit press the start button again and then car said transmission malfunction. I'm going to go crazy.
Awest91
Sep 17, 2022 11:05 PM
shoryuken15
Apr 9, 2015 03:42 PM
Stranger12
Apr 5, 2015 10:42 AM
james69z28
Mar 23, 2015 06:45 PM
RichReg
Jun 20, 2003 06:29 AM
