Help bunch of error codes from vvt and dme
Old Jun 16, 2020 | 06:44 PM
5SeriesPanvh's Avatar
My Ride: BASE 2006 530i
Unhappy Help bunch of error codes from vvt and dme
HELP!! I just bought this 2006 BMW 530i.
I have all these issues:
FAULT CODE #2a3c
#24a3
#2aa8
#2ad0
#CD99
#2DEC
#2e87e
#2ee3
Is it worth fixing? love the car.
Old Jun 16, 2020 | 09:50 PM
oleh007's Avatar
My Ride: BMW 528i
Engine: N52
Can you give us a little more information? Like was the car sitting for a long time? Did it ever over heat? Here is what I found about the codes:
2A3C = VVT Motor Supply Voltage (Bank 1)
Not really sure what this is, could be a bad relay going to the Valvetronic Motor?
24A3 = Could not find a code.
2AA8 = Fuel Pump Speed Too High or Low; Fuel Pump Emergency Operation; Fuel Pump Over Temperature Condition
This is what my Bentley Service manual told me. Im assuming you may need a new pump. Searches of the code online however revert me to DISA unit inside the car.
https://www.bimmerfest.com/forums/sh....php?t=1309893
2AD0 = Transmission Control System MIL Request
This one is a bit tough to pinpoint. Folks at this thread replaced a Crankshaft Position Sensor and it worked for him.
https://www.bimmerforums.com/forum/s...efore-starting
CD99 = Could not find a code but a couple threads mentioned that your mechanics sleeve needs to be properly seated.
https://www.e90post.com/forums/showthread.php?t=1136758 and https://www.bimmerfest.com/forums/sh...d.php?t=918949
2DEC = Powermanagement Exhaustive Discharge/ Powermanagement Defective
Battery dead or cable to front box bad. Make sure to check the battery and that it is working and not too old. Check the IBS as well as the cable.
2E87E = Could not find this.
2EE3 = Engine Coolant Temperature Gradient Too High
This indicates that your coolant temperature shot up really high. Maybe the car got overheated or a sensor went bad?
Give us some more information and hopefully others can chip in to say if they have experienced any of these codes themselves.
Old Jun 17, 2020 | 02:18 PM
After speaking to mechanics it seems the car overheated once or multiple times before.
Old Jun 17, 2020 | 03:03 PM
You are awesome! Thank you very much!
cointilt
Feb 19, 2017 08:13 AM
rocky5
Oct 15, 2013 09:50 PM
so1o
Dec 18, 2009 01:19 AM
chris f
DIY: Do It Yourself
Nov 22, 2009 02:22 AM
