Help! Bilstein B8 Sports - Rear
Old 12-23-2015, 04:36 AM
Hyper_545i's Avatar
My Ride: 545i
Engine: N62
Default Help! Bilstein B8 Sports - Rear
Good Morning All,
I am getting ready to install the Bilstein B8 Sports on the rear of my 2004 BMW 545i. The one thing I am not sure of is do I need to install Bump Stops? I know I did not need to install bump stops on the front as they are internal. Are bump stops needed for the rear? I quick search yielded a 50/50 answer. Can anyone who has installed the Bilstein Sports confirm please?
Old 12-23-2015, 10:25 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
yes, you need bumpstops for the rear dampers, the internal bump stops are only on the front dampers.
I have B8s on my 530i.
Old 12-23-2015, 06:56 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
I put B8's on both ends - and the rears came with bump stops on the damper.
Yours didn't??
Old 12-24-2015, 02:59 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Yours didn't??
yes, they did. I still trimmed them down a bit. The fronts have an internal bumpstop, the rears don't. I think that's what OP wanted to confirm. The rear B8s do not have an internal bumpstop.
Old 12-24-2015, 05:46 AM
Hyper_545i's Avatar
My Ride: 545i
Engine: N62
Thanks guys! I didn't have a chance to open up the boxes. I will double check when I get home tonight.
KyleB,
Why did you trim them down and how much did you trim off? Is this necessary?
Old 12-24-2015, 09:36 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
In all honesty I can't remember if the Bilsteins came with bumpstops in the box. But you definitely do need to have bumpstops installed on the rear dampers.
I trimmed them down because I paired the B8s with Eibachs, and they looked a bit long to me. If you're not changing springs what I would do is just transfer the bumpstops that are on your OEM shocks over to the Bilsteins.
Hope this thread answered your questions, good luck with your car.
Old 01-14-2017, 02:09 PM
wellison's Avatar
How did you get the three studs to align up in the rear shock tower, it's a bitch to see the studs from in the trunk!
bananfiu
05-17-2015 05:29 PM
ashamlawi
05-08-2015 06:50 AM
stillak
04-22-2015 04:30 PM
MrMack
03-31-2004 07:33 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: Help! Bilstein B8 Sports - Rear
