Help 530i 04 Couple of things creating problems
Old Sep 19, 2020 | 02:00 PM
BBoy123's Avatar
My Ride: bmw 530i 2004
Default Help 530i 04 Couple of things creating problems
Another day another problem with my 530i. F*** thIs car.
1: Wipers Error on the Dash and wipers going off by its own.
2: Windows up or down Not working.
3: IBS sensor or comfort access is killing my battery (as diagnosed by some other Forum) everyday over night. Any suggestions are appreciated.
Everytime i have to jump start it to run if the battery is gone low (because something in the Car is staying Awake)
When I turn Off the Car it makes 3 sounds in a repetitive order when key is turned off. 100% those 3 sounds are killing battery overnight.
Old Sep 19, 2020 | 04:40 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
If you don't know how to test a fuse for a draw pull the fuse to see if it makes a difference. The easiest way for you to find out which system is causing your issue.
Old Sep 19, 2020 | 04:49 PM
donpb's Avatar
My Ride: '06 530i N52
You need to isolate the culprit and / or get someone to read the BMW codes (or buy a DTC reader).
Old Jun 9, 2021 | 06:33 PM
RedGorilla's Avatar
Probation Members
My Ride: '04 530i titanium grey, shadow line package, adaptive headlights, active steering, dynamic drive,
Engine: M54
Have you looked at the MPM under the spare tire? If it got damaged from water it can screw with this.
Old Mar 14, 2022 | 04:55 AM
Flguy76's Avatar
My Ride: 2004 BMW 530i, 2010 535, 2010 535xi
is this a manual manual so what cash price for it, that is if u part out.... I need manual for my turbo setup on my 530i
ggracing04
Mar 14, 2022 04:59 AM
Adz
Apr 8, 2016 12:58 PM
abec
Dec 7, 2013 07:26 AM
Autobahn62
Nov 19, 2013 10:18 AM
steeda106
Lounge
Feb 10, 2010 10:16 PM
