Heating issues
My Ride: E60 545i stock
Dear all
Is there anyone who can help with this
I have heat on driver side but no heat passenger side even with dials on max
Any ideas anyone
Any ideas anyone
Engine: 3.0 B58; 3.0 M54
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Likely be the control valve however I have replaced mine PLUS the auxiliary heater pump both as my problem is lots of heat in the passenger foot well but hardly any (just lukewarm) for the driver's, been that way ever since I got
this car 6yrs ago......beginning to believe it’s a “feature” of the 2004 model.......
Both valve and pump are easy to diy with minimum special tools, I used small locking pliers and hose pinchers on hoses to prevent coolant loss.
Did a writeup on it either here on the other forum.
good luck
good luck
good luck
good luck
Engine: N62
pls explain what is a blend motor issue and how can it be tested?
Not tested anything yet i get powerful flow of air but no heat. (Passenger side only) Its a weekend car so i will test AC to see if thats ok and get back.thanks for replies. Where is the part on the car
thsnks
thsnks
Engine: N62
A blend door actuator/motor controls the blend doors (open and close). When the HVAC is changed the actuators open and closes doors to allow air flow. When non-operational they get stuck. It gets more technical but you should get the gist. Below is a pic of one. Our cars have a lot of them. Also it could be the module itself.
Engine: N62
