Headlight more hazy after using Mother's Headlight Renewal Kit
My Ride: 535
I beg to differ.
Attachment 147875
Attachment 147876
I used a 3M kit on each headlight assembly. It took me an hour or so per headlight. Don't rush the job and you can get very good results.
I put a coat of liquid 3M wax on the headlights to protect them from UV rays.
Attachment 147875
Attachment 147876
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
i bought the Meguiar's ball and used some polishing compound on the headlights and sidemarkers and that cleaned them up quite well.
My Ride: 2006 BMW 530xiT
I like the 3M kit, but I had a Porter Cable random orbital polisher so I went over them with 3M rubbing compound and Meguiar's m205. I could have also used the m105/m205 combination. I also had some extra sanding disks from a Meguiar's kit so I ended up using 500, 800, 1000, and 3000, then rubbing compound, and finally m205. Use plenty of water at each grit. If you think you sanded enough, wipe it off and sand one more time. You can get them nearly perfect. When it warms up I will polish mine again and then clear coat them to protect them.
![Headlight more hazy after using Mother's Headlight Renewal Kit-img_0034.jpg](https://5series.net/forums/attachments/e60-discussion-2/148965d1482365800t-headlight-more-hazy-after-using-mothers-headlight-renewal-kit-img_0034.jpg)
![Headlight more hazy after using Mother's Headlight Renewal Kit-img_0035.jpg](https://5series.net/forums/attachments/e60-discussion-2/148966d1482365800t-headlight-more-hazy-after-using-mothers-headlight-renewal-kit-img_0035.jpg)
![Headlight more hazy after using Mother's Headlight Renewal Kit-img_0036.jpg](https://5series.net/forums/attachments/e60-discussion-2/148967d1482365800t-headlight-more-hazy-after-using-mothers-headlight-renewal-kit-img_0036.jpg)
![Headlight more hazy after using Mother's Headlight Renewal Kit-img_0037.jpg](https://5series.net/forums/attachments/e60-discussion-2/148968d1482365800t-headlight-more-hazy-after-using-mothers-headlight-renewal-kit-img_0037.jpg)
umnitza
11-03-2015 02:58 PM
umnitza
08-20-2015 04:34 PM
PelicanParts.com
08-20-2015 01:25 PM
PelicanParts.com
08-13-2015 01:45 PM
