Headlight adjustment
Old Jun 18, 2004 | 01:54 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
ah... ok... didn't knew that...
Old Jun 18, 2004 | 01:59 PM
BMW530's Avatar
Still not sure why they do that though
Probably some startup procedure for some unknown reason
Old Jun 18, 2004 | 02:08 PM
paasan's Avatar
A sensor is attached to the rear axle. This sensor informs the headlights about how much weight is loaded to the rear axle - and as a consequence, the headlights are adjusted accordingly in order to avoid insecure dazzling of on-coming traffic.
I believe this is mandatory with xenons as they normally are more powerful than regular halogen lamps.
And.. the auto-adjustment is working continuously while the lights are on. However, on the E46 I believe there is a 20 second lag, which is considerably reduced on the 5er.
-paasan
Old Jun 18, 2004 | 02:16 PM
Iceman's Avatar
Model Year: 2013
Yeah, that's what I knew...
but what I didn't knew is, that the e60 is also doing this startup procedure without having xenons. I thought it's just when you have them. However... I have xenons
Old Jun 18, 2004 | 02:29 PM
BMW530's Avatar
Maybe the moving / leveling lights on the non-xenons when first switched on are to check that the mechanism is working?? Just a guess.
Old Jun 18, 2004 | 02:34 PM
alohalc's Avatar
oh guys, since we are talking about headlight, i know it's off topic but i want to ask anyway. i have posted another question (under "fog lights") here but no response yet. i'm so anxious to change the light bulbs but no luck so far. could you guys please go there and check out my question and see if anyone can help me out? i really appreciate it.
Old Jun 19, 2004 | 04:20 AM
535D Sport's Avatar
Originally Posted by NickP' date='Jun 18 2004, 09:24 PM
You mean the ride height/weight adjustment (dip adjustment) [common on Europe cars?]
I most definitely do mean this.The car dose not have xenons they are normal headlights.On my first E60 I had an adjustment wheel next to the dimmer for the dashboard lights but on this one nothing.
Old Jun 19, 2004 | 04:38 AM
JDN's Avatar
JDN
There is a wheel similar in the light control group to the left of the steering wheel that dims the dash display. That whole group is hard for me to see from the driving position and the knobs are not designed that well for touch control. Once you locate certain functions by touch, it gets easier.
Old Jun 19, 2004 | 07:05 AM
535D Sport's Avatar
JDN
As i said in my last post i do not have a wheel next to the dimmer for the dash lights.Have just been out to the car and discovered that it has automatic headlight adjustment, I thought that you only got this when you have xenons ?
Old Jun 21, 2004 | 04:17 AM
BMW530's Avatar
530dse,
So did I. I thought it was only on xenons too.
How and where did you find out that the car had automatic headlight adjustment?
