Head up display question
My Ride: White/Tan, Nav, comfort seats, sport steering wheels, sport suspension, active steering, rear window shades, rear shade, heated seats
Model Year: '07-530i
The display is way too low to be seen...Is there any adjustment where you can move the display up so that it can be easily seen ?
Thanks
Thanks
The forum search function is always available for your question-answering pleasure
https://5series.net/forums/topic/271...play-hud-work/
To the OP: you can adjust the brightness setting of the HUD through the iDrive. I don't know the exact sequence of menus to go through, but I recall it's pretty intuitive, as I've adjusted the brightness a couple of times.
One more comment that might help you out: the HUD appears very dim if you're using polarized sunglasses, so you'll need to ditch those to see the HUD clearly.
Good luck!
UPDATE: Apologies, I misread the OP. I thought OP was talking about brightness adjustment, not the height of the HUD.
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires
2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades
ON ORDER
cheers
vern
My Ride: 2008 550i Space Grey Metallic - 6 Speed Manual, Sport, Premium, Comfort, Cold Weather, HUD, Navigation, Night Vision, Shades, L7 Sound, Heated/AC Seats
My Ride: 2008 BMW 550i
2006 BMW X3
OP, have you tried adjusting the seat height? The hud is probably set to be spot on for the higher seat position. All of mine have been. The Performance Center and other places I've been, also recommend raising the seat until you have about a fist width of clearance. It may not be the low laid back position that looks so cool, but is better for control of the car and accident safety. Just don't get too close to the wheel and air bag.
socale39
09-05-2023 08:30 AM
