HDD space for Music
Old Jul 25, 2013 | 03:06 AM
image969's Avatar
Default HDD space for Music
Has anyone successfully swapped the iDrive HDD for a bigger one, to partition a larger space for music.. 12GB just isn't cutting it.
iPOD menu is ugly, and takes extra steps to choose a song
Flash drive takes too long to load compared to idrive HDD
Just wondering if anyone has pulled it off. Seems like it'd be possible, but a very expensive mistake if you mess something up.
Old Jul 25, 2013 | 07:00 PM
dbond's Avatar
There is about 24Gb free space available on navigation partition. You can repartition it or link /mnt/hbmedia/entertainmentserver there (not tested). If 24Gb of additional space does not cut it for you, your only option is buying a bigger PATA drive.
Code:
/dev/hd0t77.5             168632     11664    156968       7%  /mnt/hbdebug/
/dev/hd0t77.4           13317836    673429  12644407       6%  /mnt/hbmedia/
/dev/hd0t77.3            1148600     49881   1098719       5%  /mnt/hbuser/
/dev/hd0t77.2            1710872    993777    717095      59%  /mnt/hbdata/
/dev/hd0t77.1            3076400   1080783   1995617      36%  /mnt/hbcddb/
/dev/hd0t77             58725528  34478181  24247347      59%  /mnt/hbnavi/
Old Jul 26, 2013 | 06:48 AM
Errowen's Avatar
My Ride: 535i XDrive M Sport Package
Model Year: 2011
Originally Posted by dbond
... If 24Gb of additional space does not cut it for you, your only option is buying a bigger PATA drive.
dbond - Does the iDrive include a PATA controller? If so, do you know its upper limits - i.e. could it handle a 1 TB IDE PATA drive?
Old Jul 26, 2013 | 02:30 PM
balbs's Avatar
My Ride: BMW
I've looked into this before. At the time the biggest laptop sized PATA drive I saw was 80GB. I doubt they make a 1TB IDE PATA drive. Everything is SATA nowadays.
Old Jul 26, 2013 | 02:42 PM
balbs's Avatar
My Ride: BMW
My bad, I misspoke. The current drive in the CIC is 80GB. I was looking for a larger IDE SSD drive at the time.
Old Jul 26, 2013 | 07:21 PM
dbond's Avatar
iDrive is based on 80Gb PATA HDD. Extracting one from the unit is fairly simple. There is a service window in front of the headunit. I'm not sure what the upper limit but I remember people installed 320Gb PATA drives no problem.
Old Jul 27, 2013 | 07:11 PM
dbond's Avatar
I can report back that a trick with moving media to navigation partition seems to work OK. Considering that I barely used 20% of the original 12Gb HDD space the newly found ~24Gb of free space is a big relief.
Code:
drwxrwxr-x  5 root      0              1024 Jan 01 00:02 .
drwxrwxr-x  5 root      0              1024 Jan 01 00:02 ..
drwx------  2 root      0              1024 Jun 10  2009 .boot
lrwxrwxrwx  1 root      0                31 Jan 01 00:02 entertainmentserver -> /mnt/hbnavi/entertainmentserver
drwxrwxrwx  2 root      0              1024 Jun 07  2013 pv_cover_cache
Yellow Dog
Nov 25, 2019 06:27 PM
bestofthebest
Jan 5, 2016 07:47 PM
msaudino
Nov 1, 2015 03:52 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
Yellow Dog
Sep 15, 2015 01:55 PM
