Has anyone changed final drive on manual 545 or 550?
Old May 13, 2009 | 02:54 AM
AlexFW's Avatar
Model Year: 2005
Originally Posted by uheenada' post='876848' date='May 13 2009, 05:51 AM
umm what do you mean by different setups?
MT and SMG use same transmission except smg has a module that controls the clutch.
They both share same parts including gearing and rear differential.
Ha cannot accept to be the second, LOL!
Old May 13, 2009 | 07:21 AM
AlexFW's Avatar
Model Year: 2005
BTW on SMG it was risky because I didn't know how the SMG would have behaved (it still doesn't work perfectly in some situations), while on the manual he is sure it would work without any risk.
Old May 13, 2009 | 08:39 AM
uheenada's Avatar
My Ride: 2005 545i SMG
Hey, do you mind if you can explain a bit more on certain situations where your smg didn't work well?
Because, when I talked to Dinan about this mod, they said no problems at all with computer.
Old May 13, 2009 | 09:28 AM
Heloha's Avatar
My Ride: 2006 550i SMG
Originally Posted by dusandimic' post='874465' date='May 10 2009, 07:14 PM
I'm seriously considering doing this and some feedbackwould be greatly appreciated.
I see many M5ers that have made rear drive ratio changes...who is offering the change for the 550? I'd be interested in hearing what they say the swap out will do for you.
Old May 13, 2009 | 10:27 AM
dusandimic's Avatar
My Ride: 2006 550i sport package, manual, black on black w/ anthracite trim, pdc, logic 7, cold weather pkg.
If you don't mind me asking, what did it cost?
Also, why did you go with a 3.15 as opposed to a 3.38?
Old May 13, 2009 | 11:36 AM
AlexFW's Avatar
Model Year: 2005
If I remember correctly, I paid parts something like EUR 600. Got parts from diffsonline.com .
Because I use to travel at 170-180 kmh and now I have 4000 rpm instead of 3600. With 3.38.. 4400 rpm, crazy!
Keep in mind that your consumption (and noise) will increase. Plus our factory 6th gear is 315-320 kmh, suitable for a travel car: now I have 290 kmh and it begins to be too short for long and fast trips.
Old May 13, 2009 | 11:48 AM
DD_545i's Avatar
Originally Posted by AlexFW' post='877383
at 170-180 kmh I have 4000 rpm instead of 3600. With 3.38.. 4400 rpm, crazy!
Negative Point #2
Negative Point #4
Are there any positives? I can't think of any.
Old May 13, 2009 | 12:04 PM
craigm1841's Avatar
Originally Posted by DD_545i' post='877398' date='May 13 2009, 03:48 PM
Negative Point #1
Negative Point #2
Negative Point #3
Negative Point #4
faster acceleration, harder pulling through the gears. 6th gear will now pull like 5th. i had some good PM discussion with the op regarding this. I will post one of my PMs, I am sure the op will not mind. it is useful info.
Old May 13, 2009 | 12:06 PM
craigm1841's Avatar
Welcome to your messenger
Re:rear diffs
Personal Message
dusandimic
Re:rear diffs, May 10 2009, 07:12 PM
sorry. I was having some keyboard trouble... what is the final drive ratio of the 550 now? If you keep a limited slip carrier, you should be fine, if you go with a POSI unit and you like taking exit ramps off the highway quickly, i hope you like drifting.
I dont know what the final drive ratio is. if it is a 3.08, then a 3.38 would greatly help acceleration, making your car feel more powerful. first gear will be extremely short, and 6th gear will pull harder. you will be able to hit top speed i suspect (155) but your RPMs will be higher. you will have less traction off the line. additionally, the higher the ratio (3.08-->3.18-->3.38-->3.55-->3.73-->4.11) the worse your fuel mileage. because lets say you typically drive 70 MPH on the way to and from work, your RPMs will be higher then before with your lower gear ratio.
I dont want to make things more confusing, but the HIGHER the number, the LOWER the gear ratio. when i say higher, i am talking about numerically.
so the rules are...
The higher the NUMBER the lower the top speed
The higher the NUMBER the lower fuel MPG
The higher the NUMBER the worse the traction (countered with a good unit and good tires)
The higher the NUMBER the BETTER the acceleration
The higher the NUMBER the HARDER your higher gears will pull
Your traction WILL BE WORSE in the winter time, however, leave DTS activated and you will be fine.
sorry if this jumped around a bit. I just got back to work from 4 days off and have a bit going on. I always have time for a fellow BMW enthusiast though. let me know if you need anything clarified
Old May 13, 2009 | 12:07 PM
mhs525's Avatar
Negative Point #1
Negative Point #2
Negative Point #3
Negative Point #4
Torque rules on the street. Here is the blurb from the Dinan website on changing M3 gears from 3:64 to 3:91 which is what I had. I loved the 3:91's.
The shorter 3.91 gearing takes advantage of torque multiplication for a substantial increase in torque delivered to the road. The improved acceleration comes with only a minor increase in engine speeds at cruise and no effective reduction in top speed
When you have a six speed trans, you never reach the cars real top speed because it is limited by the ECU. Therefore with "shorter" gears you get faster acceleration with no loss of top speed but you do use more gas...
