Fuel
Old Feb 1, 2005 | 12:44 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by heli_ca' date='Feb 1 2005, 09:31 AM
I have been running 91 octane, but now I see that 94 octane is available at Husky(Canada).? Anyone try 94 and notice any difference?
[snapback]85468[/snapback]
94 US is 100 over here in Germany.
I use it all the time.
Some ppl think it is better, some don't believe in it. I just don't care about the couple cents and fuel up with 100 octane all the time, since it doesn't harm the engine. But I can't tell if there is a difference, since I've never tried anything else on the E60.
If you search you'll find a couple topics about this.
Old Feb 1, 2005 | 01:12 PM
robg's Avatar
My Ride: 2008 550, Carbon Black Metallic, Natural Brown Dakota Leather, Sport Package, Sport Automatic Transmission, Cold Weather Package, Power Rear and Manual Side Sun Shades, etc. Retired - 2004 545 SMG, Black Sapphire Metallic, Auburn Dakota Leather, Cold Weather and Sports Packages, Power Rear and Manual Side Sun Shades
Originally Posted by 530iii' date='Feb 1 2005, 03:46 PM
Sunoco Ultra 94. ? Where can i get 100+ octane in the NYC area at the Racetrack (Englishtown maybe)?
[snapback]85709[/snapback]
Save your money. Do not buy 100 octane gas. Your car will not perform better. Buy the recommended octane. If that is not available, buy the next higher, ie 94.
Even the gas companies concede there is no benefit to higher than suggested octane.
This is from the Mobil web site:
"Ordinarily, your vehicle will not benefit from using a higher octane than is recommended in the owner's manual. But if your engine knocks or pings at the recommended octane level, you may need a higher octane gasoline to prevent the knock."
Old Feb 1, 2005 | 01:31 PM
Iceman's Avatar
Model Year: 2013
[snapback]85752[/snapback]
Over here they do!
Old Feb 1, 2005 | 01:34 PM
subterFUSE's Avatar
The Sunoco station by my house sells 104 Octane (and that is USA octane rating), or something ridiculous like that.
It costs like $4 a gallon.
Never tried it before.
Old Feb 1, 2005 | 01:35 PM
Iceman's Avatar
Model Year: 2013
[snapback]85771[/snapback]
That's racing gas.
Old Feb 1, 2005 | 01:39 PM
robg's Avatar
It is for high compression engines - much higher than the E60- and will not benefit us.
Here isa good, simple explanation: http://auto.howstuffworks.com/question90.htm
Old Feb 1, 2005 | 07:05 PM
Guest
Guest
Posts: n/a
Originally Posted by subterFUSE' date='Feb 1 2005, 03:41 PM
Except California (and maybe elsewhere that uses the same CFG standard?) which has 91 instead of 93. We use to have 92 but the common carrier pipeline and a dispute over royalty payments for the technology to make that one point boost ended that. We do have 100 racing fuel (unleaded) but it's over $5/gal.
That's because California always has to be different.
[snapback]85707[/snapback]
No -- it's because of the stricter emission regulations (more restrictive than the federal EPA, which applies everywhere else) for automobiles in CA. The petrol providers have to sell a more expensive, reformulated gasoline that is available only at a (R+M/2) rating of 91 (I have not seen a higher premium unleaded rating in SoCal, although I am constantly checking for it). None of us in CA enjoy paying more for a reformulated gasoline just "to be different!"
Iceman is correct -- there is no benefit to buying the higher octane rated gas for the e60 in the US as BMW tunes the engines for the "lowest common denominator"/minimum octane rating available across the entire US (which I believe is 91).
Old Feb 2, 2005 | 03:37 AM
cobradav's Avatar
Originally Posted by gdavis' date='Feb 1 2005, 06:34 AM
It might be worth including which system of octane ratings are being used in each of your county as you post, since some countries use different rating systems which results in slightly higher or lower numbers for the same level fuel. You might want to check on the pump and see if it is RON method or the other one, which can help us compare them.
I know the system in Europe uses a different one than in the US, and I don't know which is used in Canada or Singapore....
The one I fill up with here in the US is 93 since 91 is marked as the minimum required on the car, and we don't have 91 in our area.
(I need to look at the pump also next time I fill up)
[snapback]85495[/snapback]
Yes there are at least two different methods of measuring gasoline octane
Here is a link to one explaination. http://www.btinternet.com/~madmole/R...RONMONPON.html
It is essential to point out that in this discussion the "PON" referenced in the article as being on the USA Pumps is now the more familiar "(R+M)/2" formula. As you can see from this, most European 98 octane discussions equate to a USA octane rating of 94, European 95 - USA 91 and so on. The gasoline companys also vary their formulas a little based on geographic and weather considerations.
Old Feb 2, 2005 | 06:03 AM
Bedford530i's Avatar
My Ride: 2004 530i 6-speed Titanium Silver/Black Interior Premium Package Sport Package Aux input 30 GB video iPod Cold Weather Package Xenon Red rear reflectors Tint Clear Bra
The Sunoco station I get gas from has 91 and 93 Octane. I always get the 93 but have always wondered whether I should just get the 91. Should I just fill up using 91?
Old Feb 2, 2005 | 06:27 AM
JDN's Avatar
JDN
Anything over 91 is wasted in the US. I use 93 a lot, too, because I don't always want to blend to save a dollar.
