front winshield rubber trim
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
My front upper windshield trim is degraded just like the rear did I I replaced the rear without having to remove the glass can the same be done with the front upper.
My Ride: 2008 550i w/M-Tech, Sport and Cold Weather Pkg
I have the same issue and have heard that it cannot. In fact mine looks horrible right now and it may be time for a "rock" to hit my windshield. Then Autolite or whomever does the replacement can put in a new upper seal.
BTW-I have all 3 needing replacement, top of windshield, sunroof seal and rear window seal. Anyone have an aftermarket site they recommend for these seals.
It can be but a little more difficult. If you search this forum there is actually a video on how to do it. I just had mine replaced but had to have the windshield replaced too so all was good. I had actually purchased the seal to install and was waiting and then a rock hit my glass.
Engine: 530i
Okay I tried to search before I posted can you give me a link maybe my wording is wrong. I have already replaced the rear I brought the front upper I also purchased the lower on that the wipers have to be removed to replace that one is looking worn also lead me tonyb and I will follow
https://5series.net/forums/e60-discu...cement-124532/
Engine: 530i
thanks
Thanks Toney I had saw that one previous but was not the e60 so I was not sure that it was the same I will try it soon as the sun comes back out
Replaced both front and rear seals last year. Took me all of 30 minutes combined, including cleaning. Word of caution...the sun was out and beating down on my windshield making it extremely hot. I was cleaning the remnants of the original gasket from the windshield with cold water from the hose. Minor chips in the windshield and cold water do not mix. I got a new windshield out of the deal plus the replacement of the seal I just replaced. Lesson learned...do not put cold water on a hot windshield.
Engine: 530i
Noted fire and ice don't mix
TexaZ3
05-06-2015 09:54 AM
ASpec818
04-23-2015 11:30 AM
