Flat Tire Warning Sign
Old 09-20-2012, 05:11 AM
alirzn's Avatar
Hi,
Yesterday the flat tire warning sign appears in I-Drive screen on my 2004 530I. I checked the tire and fill the tire based on the BMW recommended pressure. But the warning sign is not removed. I read that I should reset the tmp. But I don?t know how I should do that and how is the tmp sign looks like?
Old 09-20-2012, 06:44 AM
Wolrab's Avatar
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
It's FTM. If you can't figure it out from the user manual, press the iDrive when it's in the Home screen. You should be able to find FTM from there, under Info Sources if I remember.
That FTM doesn't monitor pressure. It monitors differential rotation rates of the different wheels. Gradually falling tire pressures (which is what is happening at this time of the year) don't trigger the FTM. You almost certainly have a leak in the tire that's soft. I'd suggest you get it fixed ASAP, then put a pound or two extra in all the tires to allow for dropping temperatures in the fall. Don't forget the spare. I check mine every week in the fall and winter, but then I'm kind of anal about tire pressures.
Old 09-20-2012, 07:18 AM
Gene's Avatar
***while resetting the ftm sensors you need to drive, not stay stationary as it resets..and usually takes a few minutes of driving before it resets as well...
Old 09-20-2012, 08:08 AM
alirzn's Avatar
In my 2004 530I, I don't have FTM option in Idrive under the vehicle setting. I have all of Oil, Brake, Filter and etc there but no FTM. So how can I reset that?
Old 09-20-2012, 08:11 AM
Gene's Avatar
yes you do have it, it's a standard option...follow page 81 in your manual...in case you don't have your manual..
https://5series.net/information/2004..._Manual_US.pdf
Old 09-20-2012, 08:50 AM
luigi524td's Avatar
https://5series.net/i...s_Manual_US.pdf
I had to jump on a conference call and walked away from my laptop - glad you picked up my slack !!
Old 09-20-2012, 09:50 AM
alirzn's Avatar
Thanks it worked and warning has been removed.
Old 09-20-2012, 10:09 AM
Gene's Avatar
team effort
Nihilation
07-10-2022 11:32 AM
StevenFW
15
02-20-2005 09:17 PM
silver4evr
04-20-2004 08:44 AM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Flat Tire Warning Sign
