Flat Tire Warning !!
My Ride: '04 525i, sport package & all the other goodies included
Driving up to Princeton today the FLAT TIRE !!! indicator starts flashing and chiming. :'( I just had new Eagle NCT 5 runflats installed a couple of weeks ago. I pulled into the nearest gas station with an air pump and tested all the tires. All normal pressure!! I reset the tire pressure indicator in the system and all has been well the rest of the day.
Anybody else have this glitch??
Just check the pressures over the next few days and see if the alarm kicks off.
When I first got my car I had loads of these over a period of a couple of weeks. I actually had a REALLY slow puncture.
Since fixing it I have had one false alarm over a rough stretch of road.
My Ride: G30 M550i
Model Year: 2018
Did you reset the system a few weeks ago when the new tires were installed? If not, then what happened today is perfectly explainable. If you did reset the FTM with the new tires, then it could have been a minor glitch and you'll be fine...
As a secondary concern, if I did not have the tire pressure monitor activated, how would I know that I had a flat on a runflat tire? (other than checking the tire pressure) What would stop me from continuing to drive hundreds of miles if on an extended trip? (which I do quite frequently)
Just what are the indications of a flat on a runflat tire?
My Ride: G30 M550i
Model Year: 2018
A primary reason for the FTM system on your car is due to the runflat tires. I don't think it would be wise to install runflats on any car without some sort of real-time pressure monitoring. (I know, the E60's rotational based system could be argued as "not real time" but that's not my point. )
You can't detect a flat visually (sure it's possible but it's not likely to be noticed right away) and many people wouldn't be able to "feel" the low tire (even though the car will feel different on a runflat with zero or low pressure).
You can't "deactivate" the FTM so your concern isn't really anything to worry about. If it isn't initialized, you'll likely get false warnings. If it is initialized, you'll be fine.
The biggest thing to worry about is that the tire pressures are all set properly before initializing. Feel free to initialize as often as you see fit, just make sure you do it after verifying your pressures...
My Ride: 2008 550i Sport Carbon Black with Black Nasca Leather Sport Auto Transmission Active Steering Comfort Access Bamboo Anthracite wood trim Power Rear Sunshades Ventilated Seats Ipod adapter Nav Sat Premium Sound
I've experienced both types of flats. First time, a slow leak and I also thought I-drive error. Drove from LA to Vegas and back (avg 80-90 mph) and no problems. Second time, I had absolutely zero air pressure (sounded horrible) The tire did the job and got me home.
Here's something interesting: Every time I have a tire replaced, I always get a flat tire I-drive warning (a few hours later). Even after the RFT monitor has been reset. Hopefully not a another slow leak!
Originally Posted by Hatchman50' post='295754' date='Jun 10 2006, 10:09 PM
Thanks Rudy...I did reset the system at that time. I'll toss the digital gauge in the glove box and monitor the tires closely for that possible slow leak.
Indication on a low pressure run flat is low pressure, best detected with an analog gauge,IMO.
My Ride: Current - 330 Sport Topaz Blue, Grey Leather, HK HIFI...lost interest!!
Waiting for - 535d Sport, Silver Grey, Foldy Mirrors, 172 19",Logic7,Pro Radio,Through load,Heated Front Seats,High Gloss shadowline,Black Maple,Headlight wash,Sun Protection Glass.
StevenFW
15
02-20-2005 09:17 PM
