Five faults when starting car
Old May 7, 2020 | 04:59 AM
xiant's Avatar
My Ride: 2006 E60 550i individual, all options besides heated stearing wheel
Default Five faults when starting car
Was going to start my car this morning and i instantly got all these at once.
i have had some of these pop up intermittentøy after going for a short drive to fill up but not all at once.
the car started up without problem, no unusual noice but the steering was really heavy so i parked it.
no fault codes found and no faults when scanning/cheking modules manually with my icarsoft v2.
I need some help!
Old May 7, 2020 | 09:03 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
How old it that battery? Might want to have it checked out. If the battery is good have the alternator checked. Those are the 2 things that can make your car go crazy
Old May 7, 2020 | 01:05 PM
xiant's Avatar
The battery and ibs sensor was changed 4 ago and the alternator was changed 2 years ago.
I remember having random dynamic drive faults when the alternator was bad and not giving proper charge before it was changed.
I checked voltage via obd and it was 12.33-12.36 when ignition was on and 14.35-14.38 on start up and after 2 minutes of idle.
I locked the car for 40 minutes and started it again with no fault codes.
Old May 7, 2020 | 01:24 PM
Ok. So you're having an intermittent power issue. It's going to be hard to find until whatever it is goes bad.
Bimmerlat
Jan 12, 2019 02:57 PM
Davese61
May 12, 2018 12:00 PM
bbbero
Sep 25, 2014 01:38 AM
mullenc525
Apr 7, 2013 06:57 AM
snadir
Mar 10, 2012 10:39 AM
