filled it up with petrol
Originally Posted by Flowerfred' date='Aug 17 2004, 09:52 AM
There was somebody a while ago that proposed to make nozzles a certain shape, so you cannot make this mistake. For exapmle square nozzle for unleaded, triangular for diesel. Seems to make sense.
OK, the closest thing I could find is a company called Hartshead.
St. Albans Avenue, Ashton under Lyne 0161-3308193
http://www.carpages.co.uk/go.asp?session=6...7046@577845@864
My Ride: [i][b][u]Since 19 august 2004[/u][/b][/i]: [color=red][b]530i[/b] High Executive[/color], Silvergray with beige interior, Popular wood, Servotronic, Sportssuspension, electric foldable and dimmed mirrors, dimmed interior mirror, pappelmaser braun wood, cupholders, styling 123 18" wheels, Logic 7, Steptronic, alarm class 3, electric sunscreen in the rear and suncreens for sidewindows, Comfort seats, heated seats, Xenon with headlightwashers, Adaptive corner lights ALC, Advanced airconditioning, lightpackage, Nav Pro, 6 cd changer, side airbags rearseats, bluetooth siemens S55, chrome kidneys, gearlever with wood, voice recognition retrofit, front windshield with green band.
Waiting for trunkopener button from Hobi :)
I would certainly try to drain most of it.. Any garage can do that for you for less then bmw..
My Ride: G30 M550i
Model Year: 2018
Can't you use a siphon or other type of pump to draw the fuel out the filler instead of paying someone to drain it?
Seems to me like a DIY job...
There is a trick with a garden hose.. You have to put it in and suck really hard. Then put it in a bucket wich contains a little bit of diesel and it should run by itself.. I've seen it once with water and it worked.. That would be the cheapest way and the riskiest since you can get diesel in your mouth.. blaaahh..
Originally Posted by 530E60NL' date='Aug 17 2004, 05:07 PM
That would be the cheapest way and the riskiest since you can get diesel in your mouth.. blaaahh.. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
duh!
![Online2long](https://5series.net/forums/images/smilies/imported/online2long.gif)
My Ride: G30 M550i
Model Year: 2018
Originally Posted by 530E60NL' date='Aug 17 2004, 12:07 PM
There is a trick with a garden hose.. You have to put it in and suck really hard. Then put it in a bucket wich contains a little bit of diesel and it should run by itself.. I've seen it once with water and it worked.. That would be the cheapest way and the riskiest since you can get diesel in your mouth.. blaaahh.. ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Seems to me it's still a DIY job -- the hardest part is figuring out what to do with the gas...
