Fault Code P1057
My Ride: 07 550i Sports Package
I got this fault code today, does anyone have any info on it? Anyone ever had, causes, fixes, etc.. Where is this part in the car? Any info would be greatly appreciated. Thanks.
Description of OBD II Fault code P1057
FUEL RAIL PRESSURE CONTROL VALVE CIRCUIT OPEN
Possible failer of OBD II Fault code P1057
?Metering Unit Actuator internal open
?M-PROP Actuator harness open
I was very interested in this fault code that you have posted as I have an issue with my gas tank. Whenever I'm fueling my car, the fuel hose cuts off (like it would when full). It does this even if I'm on E. So I basically have to stand there pulling the lever every few seconds until it fills up or I get fed up and leave. Have you had issues putting gas in your car? In trying to look this up, it looks like it may be an issue with pressure build up in the gas tank due to a faulty circuit...
linxuan
E39 Discussion
Mar 22, 2015 06:16 AM
