Extreme vibration, please help
Old 03-19-2019, 02:33 PM
e60jh's Avatar
My Ride: E60 N52 -06 m-sport auto 180k
Engine: N52
Default Extreme vibration, please help
Hi fellas
My car is E60 525i -06 N52 automatic
I'm having a major issue and I'd kill for your input.
It used to have a very rough idle when AC was on, when off - mild to nothing. But I couldn't find a solution and taken that there's no symptom when ac off I just drove it like that and everything's been perfect.
Yesterday I had a drive, I quickly reversed from gravel on the side and up on the road hitting a small edge that shouldn't do something but it did.
From that moment my car is having extreme vibrations, at idle, startup, low speed, when I turn the steering wheel. It feels like the engine/box is about to collapse and it's worse when I switch gear to reverse. At startup it sounds quite sad and eventually cranks. At high speeds, nothing, not a single symptom.
The whole car is literally shaking, I feel it in the chair, steering, pedals, body.. the whole car.
I have attached Carly diagnostics report if that gives you any insight.
I truly appreciate your help, it means a lot!
I'm going through life and hell right now so I was thinking to sell the car in ~ 1 month but this just drags me down after I had to replace parts for $2000 some weeks ago.
Once again, thank you.
Old 03-20-2019, 05:17 AM
audiophool's Avatar
My Ride: 535xi
Check your engine mounts.
Old 03-20-2019, 05:48 PM
e60jh's Avatar
Engine: N52
Thank you
So it'd make sense to be the engine mounts, do you have any idea how I can error search them without taking off the undercover shields/engine parts?
It's crazy to pay $500 per mount + labour at the mechanic
I'm far away from home and got no tools.
I've had a quick look and found something visual:
Where did you escape from buddy.
Old 03-20-2019, 06:33 PM
tstiglich's Avatar
My Ride: 2009 528i xdrive
Odd place for a bolt..... I would start there.
Old 03-21-2019, 05:23 AM
audiophool's Avatar
My Ride: 535xi
Looks like an aluminium bolt. Broken. Likely from the valve cover area if it's an M6.
If you open the hood and have somebody else put the car in gear and brake-torque the engine, you might see it move around on the mounts. A little flex is OK, a lot of movement is not. Try in D and in R.
Old 03-21-2019, 10:42 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
Reminds me of the bolts that hold the stock strut bar in place on top of the engine.
sorry, forgot those are Torx, not Etorx
Old 03-22-2019, 07:56 AM
Arif Halim's Avatar
My Ride: E60 n52b30
Originally Posted by e60jh
Thank you
It look like cover head bolt. Check for the others bolt on morning, with cool engine condition. If loose, maybe, there was air leak from head cover gap and changing air fuel ratio. The air leak, makes air flow straight to combustion chamber without going through MAF. And there will be unusual vibrations. Also still check engine mount and transmission mount.
Jucas Blue
09-12-2011 06:35 AM
seru788
05-08-2010 10:38 AM
M5Power
Meet & Greet Discussion
10-10-2007 09:49 AM
Postel
The Competition
11-08-2005 01:18 PM
Presley348
11-23-2004 06:31 AM
Quick Reply: Extreme vibration, please help
