Error 9C77
Old May 20, 2013 | 10:13 AM
micosan's Avatar
Originally Posted by kskane
Another question, while I am trying to figure out the Aux water pump problem. The code 9C77 was read via INPA. Most places in the forums post a code that starts with P?????. What is the difference and how can I find those codes?
Any help is appreciated.
The first picture is the Auxillary water pump. It is item seven in the link
RealOEM.com * BMW E60 550i Water valve/Water hose IHKA Basis
BMW DTC
http://ebookbrowse.com/bmw-hex-codes-pdf-d236223578
Old May 20, 2013 | 01:20 PM
AchtungE60's Avatar
My Ride: E60 530i
If you are using some generic scanner, do not assume that the error codes are 100% correct. If using INPA then 9C77 is the proprietary code. If you do have this option you can activate it in INPA. probably under CHASSIS. Just look up your VIN and if it came factory you'll have the option. it's as simple as that.
A P-code is a generic code from a generic OBD reader.
Old May 22, 2013 | 07:02 PM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
Thanks AchtungE60, I have INPA on a laptop which connects to the vehicle over K+DCAN USB cable. So what you are saying above, any code obtained from generic OBD reader will definitely be captured with INPA as well?
BuddyB
Aug 17, 2017 12:48 AM
fabolous531
Oct 18, 2015 12:22 PM
alienintelligence
Sep 7, 2015 12:09 AM
umnitza
Sep 2, 2015 11:28 AM
Bounce
Aug 31, 2015 10:04 AM
