Engine will not start
Hey everyone.. not too long ago I made a post regarding my car not starting and what not, and people in the community told me to fetch a new battery for my car. Thread: https://5series.net/forums/e60-discu...-129762/page2/
I did this and installed the new battery into my car, hoping to get the car back on the road. Unfortunatly I was let down.. Everything from lights inside the car, Idrive / nav screen and lights outside the car work properly, but the car will not start. I took it to a garage (not bmw certiefied however) but they checked all the amps and wires and nothing was wrong, they even ran diagnostics on the car and nothing showed up besides some faults in some unit. They now told me that is was probably a processor / brain / unit or what you would call it that has either lost software and / or is broken physically. My question is if anyone here has had this problem, and know how to solve it in a cheaper way then putting it to a new garage for several hours and what not!
I appreciate all help, thanks![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
- Jannick
- Jannick
My Ride: 07 550i Sports Package
You should check the sync between the DME and CAS, mine got messed up and I had to replace the DME. After I replaced the DME and pressed the button nothing happened until I did the sync. Also, it seems you are not very knowledgeable with this car, it will be hard for anyone on here to diagnose the car from afar, maybe you should just take the car to the dealer, just to find out what is wrong then you can fix it yourself. You can have your insurance company foot the cost of towing.
Replacing a starter on any car is never fun. Not hard, but usually involves getting under the car and supporting one end of the starter with your arm, while you unbolt the other end. Not always easy. I can imagine on the e60, it's more difficult that it normally is.
If you can hear the clicking of the starter, then I would look at the sync DME -> CAS that was mentioned also. You should probably test the voltage to the starter using a Volt-Ohm-Meter if you don't hear it clicking.
I think the DME is pre pretty cheap (~$200) and can be found in a lot of places online
The clicking noise comes from a solenoid attached to the starter which engages the starter motor gear with the engine and passes the voltage coming from the ignition system to the starter motor itself.
If the clicking noise is not present, either the solenoid has failed or the rest of the ignition system has not passed the starting voltage to the solenoid (and in turn the starter motor).
If the clicking noise is present but the starter motor does not turn over then it is almost always the starter motor (loose connection between solenoid and starter is very rare), that needs to be replaced.
To the OP- I am not that familiar with the 520i engine, but I would imagine it is the straight six block and starter replacement usually necessitates removing the intake manifold. If you can get a probe to the solenoid connection you might be able to test if the solenoid is receiving a voltage when you engage the starting system (assuming you do not hear a click when engaging the ignition system).
I think you know how it works but you are missing a component in the chain of events.
Yeah, good point. The solenoid is what actually clicks and (I think) completes the circuit and engages the motor as you mentioned. Just hearing the click doesn't rule out the Starter. Thats why I suggested the additional diag using the VOM
Not sure how I posted that w/o mention of the solenoid....must have posted before my coffee =\
On most cars if it isn't the battery or starter things are narrowed down quickly, but with these BMWs you throw in smart battery cables, power modules in the trunk, voltage modules in the ebox, yada yada yada - You need a BS in Electrical Engineering to trouble shoot it.
thesalboy
04-08-2015 09:13 AM
