Engine Oil Level Message Question
Old Feb 13, 2019 | 11:48 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
My typical driving distance is about 32 miles one way to work and then another 32 miles back home. This happens about 1 to 2 times a week. For short distance driving, I think it may be about 15 miles one way and then another 15 miles back home. I am not sure whether these count as short distances.
Thanks,
Ching-Ho Cheng
Old Feb 14, 2019 | 08:14 AM
audiophool's Avatar
My Ride: 535xi
32 miles is not a short trip by any means.
Another possibility is you've started an oil leak and since there are belly pans on these cars, an oil leak can go undetected for a long time before it starts dripping on the floor. My E53 X5 was losing a litre every few hundred km and most of it was on the belly pan. I think most of it came off while I was driving, so it never made more than a quarter sized drop on the garage floor.
Old Feb 14, 2019 | 08:40 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Good point!
Old Feb 14, 2019 | 09:10 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
I will remove the undercover to check when next oil change come (it will be soon, less than few hundred miles to go).
Thanks,
Ching-Ho Cheng
Old Mar 4, 2019 | 02:56 PM
donpb's Avatar
My Ride: '06 530i N52
Originally Posted by lcc014
Yesterday, when driving to work, I noticed that the small exclamation mark was on in the center display. So I went to "Info Source" --> "Check Control Message" to check. It showed "Engine Oil at minimum level". My 2004 530i never has this message until now (after 14 years). Is this normal to our E60 ? I followed the instruction from the message to add 1 Qt back to engine. I have not driven the car yet. My co-worker's E90 always need to put in 1 quarter once a while and dealer could not find any oil leak under the engine. Another co-worker of mine has E60, 2006, same issue. He needs to put in 1 quart of oil once a while. He said that is typical ?
Any comment is appreciated.
Thanks,
Ching-Ho Cheng
Mine does that every once in a while but I have a leaky oil pan gasket. If you fill it a quart and the message does not go away, its the sensor or the wires. I had my mechanic look into mine and he said it looked like some rats chewed on the wires. He soldered them back together and all has been fine ever since.
Palmo
May 14, 2016 12:14 AM
Redneck
Apr 9, 2011 05:31 PM
chosenone357
Aug 6, 2009 05:10 AM
amit1947
May 7, 2009 06:30 AM
ls78000
Jul 14, 2005 04:18 AM
