Engine malfunction/too rich after fixing injectors
Old 02-20-2019, 01:21 PM
BurtonSnol3order's Avatar
My Ride: 325i
Here are the logs. MHD kept having issues connecting, but that's what it gave me. Any input is appreciated.
Old 02-27-2019, 06:29 AM
My Ride: 325i
Just a bit of an update. I used MHD to continue to clear codes. I noticed very apparent misfires when MHD connected to the ECU each time. One time it even totally killed the engine.
That being said, it is running better now. The only lagging issue is the "engine malfunction" light that shows up when I am WOT in 3rd gear around 5500 rpm. I feel no misfire and there are not any engine lights other than the malfunction indication. When I pull DME info right after the malfunction indication i get a "30FF - Turbocharger, charge-air pressure too low" but it runs fine anyways. After a restart, the lights are gone again until I do a hard pull through 3rd gear and it'll come back.
Old 02-27-2019, 09:34 AM
NoQuarter's Avatar
Engine: N54
You could have a boost leak.
Places to check:
- Check the plastic charge pipe going to the throttle body (these like to crack)
- Check the diverter valve connections
- Check the connections to the intercooler
- You could have bad wastgate solenoid(s)
- Check all the vacuum lines especially to the wastegates
Are you near Northern Indiana?
Old 03-01-2019, 05:35 AM
My Ride: 325i
Places to check:
I was thinking charge pipe. Do i need to vacuum test the diverter valves, intercooler connections and vacuum lines?
I'm about an hour north of Indy. Where are you located?
Old 03-01-2019, 05:50 AM
NoQuarter's Avatar
Engine: N54
The vacuum system will hold a vacuum for a while after the car is turned off. A good test is to pull one of the vacuum lines off and you should hear a woosh of air if there is still a vacuum. If there is no vacuum, then there is a leak. If all the vacuum lines are original you should just replace all of them anyway. Be sure to slice the vacuum line where it connects to a plastic nipple or use a pick type tool to insert and break the connection loose. Those plastic nipples will break off.
Short of just a visual inspection of the intercooler connections, you would have to do a pressure test or smoke test to check for leaks.
I'm further north in South Bend
Old 03-30-2019, 09:34 AM
My Ride: 325i
Just so anyone else comes upon this thread. I ended up buying 4mm vacuum lines from verocious motorsports online. I ended up just swapping out the lines between the diverter valves, intake manifold, etc. I ran some compressed air through the DVs while they were out and everything is back to normal.
Old 03-31-2019, 10:26 AM
NoQuarter's Avatar
Engine: N54
Nice result!
Tanner Godby
04-02-2018 05:55 PM
spediegunz
03-29-2014 07:32 PM
dezifresh19
01-26-2014 12:14 PM
daydok
Lounge
08-03-2005 09:28 AM
JDN
Lounge
18
08-02-2005 09:44 AM
Quick Reply: Engine malfunction/too rich after fixing injectors
