ENGINE MALFUNCTION, REDUCED POWER - Error message
#31
My Ride: 2008 535i
Alpine White/Black Dakota Leather/Bamboo Anthracite Wood Trim/Anthracite Headliner
Premium and Sport Package
Comfort Access/Navigation/HD Radio/iPod/Logic 7/SAT/PDC
Sprintbooster
Split Second Turbo Tuner
BMC Air Filter
Update: I installed my SB yesterday without a hitch. No error codes popped up at all. One thing to consider is to match up the numbers inside the housing of the SB with the numbers inside the housing from the accelerator. You'll see 2 rows of number, from 1 to 6. Just match, plug in, and get ready to lose MPG.
#32
My Ride: 2008 BMW 528i, Monaco Blue Metallic, Beige Leather, Premium Package
![Unhappy](https://5series.net/forums/images/icons/icon9.gif)
Originally Posted by owwo' post='557939' date='Apr 8 2008, 09:54 AM
Did you guys get your SB's yet? Any install or engine malfunction problems like the ones described?
#33
My Ride: 2008 535i
Sprintbooster
BMC Air Filter
Originally Posted by riffraff' post='561263' date='Apr 14 2008, 01:00 PM
I received an email saying it was shipped on the 12th. Getting a little apprehensive about installing it after this thread though.
#34
My Ride: 05 530i M Sport Sedan / Silver Grey
Guys,
I just installed my SB, first time around i got the same rough idle and error message as described by others. I checked that i matched up the numbers on the pins and the plugs where fully engaged the second time around and the idle was fine but now i have the check engine light on the diplay but no service error messsae in I-drive.
Do i have to take it to the dealer to reset or should i take the SB off and see if it rights itself? If i have to go to the dealer what do i tell them, i dont want them hunting around for problems that aren't there and charging me for it?
#35
OK so i took the SB off and the check engine light went away.
I reinstalled the SB and again but got the spluttering idle again so i swithch it off for further investigation.
On the end that plugs into the pedal there is numbers on both the female and male conneectors, i checked that they all lined up correctly. On the other end there is number on the female connector but not the male connector on the SB. I turned the S/B the other way around and plugged it in and statered her up agan.....hey presto the idle was fine and the engine check light is no longer on.
So my deduction is that (in my case anyway) the end that plugs in to the wire coming out of the carpert should be connected a particular way up even thought it is possibe to engage it by rotating it 180 degrees. The male connector on the S/B should have numbers on the male connectors so it can be lined up with the female connector coming out of the carpet.
If other members are having the same problem i did please try what i have suggested as this may rectify your problem, it did in my case.
I have only drive to the office in traffic so far with the S/B on but i have noticed that the accelaertation is more sensative, i think i may need to reset the transmission because the gear changes seemed a little off, or maybe i just need to drive abit more and the trans will "learn" how to change with the S/B fitted.
Originally Posted by MatyB' post='561657' date='Apr 15 2008, 02:22 PM
Guys,
#36
Did it at least seem to go together more naturally when you rotated it. I could see it going together incorrectly but with some force and more or less stretching the socket on the plug to get it in there or maybe our factory plugs vary a little. I more or less match the curved side with the curved side albeit they are not identical curves. There is a definate flat side on both plugs.
Good to hear that someone tried to re-install it differently before returning it so that the rest of us know there is no 'real' concern here to be worried about even if ours appear to be working fine...
Thanks for doing that and posting your results...
#37
Originally Posted by Glock-357' post='562265' date='Apr 16 2008, 02:29 PM
Hmm, I must stand corrected in the other thread. I thought the plug would not allow this due to the flat side and I even tried today to plug it in backwards (without any real force, of course). I thought I tried all possible incorrect scenerios.
On another subject has anyone come up with neat way of hiding the S/B, i can seem to hide the red cable behind the pedal because it is some damn long, in relative termss of coarse?
#38
My Ride: 2008 535i
Sprintbooster
BMC Air Filter
Off topic, glock-357 do you own the glock .357 G31 or G32?
#40
Originally Posted by owwo' post='562666' date='Apr 16 2008, 03:18 PM
I echo glock-357's comments on the orientation of the plug. I too noticed that when I tried to plug it in incorrectly the other way, it wouldn't plug in. Once I rotated it the correct way, it slid in like butta.
