Engine Malfunction, reduced power
My Ride: 2004 530i
Hi guys,
Nice to be here. I'm quite new here.
I drive a 2004 530i of 207,000 mileage.
Yesterday morning, I drove about 10km and I got an error message on the iDrive screen that says "Engine malfunction. Reduced Power"
From that moment, the car began to misfire like jacking, lost proper acceleration and could not move as it ought to.
So I parked it somewhere till the following morning.
When I started the engine the following morning, it still displayed that error message and was misfiring. Then I switched off the engine and started it again.
By the time I started it the second time, the message disappeared. I drove it for over 100km without issue. The message didn't reappear and the car didn't misfire till this moment.
However, that morning before I embarked on the trip, I scanned it here is the specific result that has to do with the Engine among other results. Full scan report attached.
SYSTEM
DME (Engine-Motor
Electronics)
CODE
281D
DESCRIPTION
Digital Motor Electronics (DME): BSD (Bit-Serial
Data Interface) generator, signal
STATUS
Present
I read about it though and what i found out is that the Alternator is Overcharging and some other technical information about BSD that I don't really understand about mechanics and electronics.
May I ask, who has had this problem before and when scanned had the same report and what did you do and how you solved the problem.?
Attached is the full Scan Results in PDF
Awaiting replies
Thank you
SYSTEM
DME (Engine-Motor
Electronics)
CODE
281D
DESCRIPTION
STATUS
Present
Awaiting replies
Thank you
Headwaters (03-20-2020)
My Ride: 2004 530i
Hi, thanks for your response, however, I just checked the voltage of the Alternator, it ranges between 14.31 and 14.62. Wish i consider normal.
Is it possible for the alternator to be bad and yet having normal voltage output?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It is a possibility to have a flaky alternator but you find that out by a long enough test. If your alternator tested good and you are sure then move to the next thing.
Headwaters (03-22-2020)
