Engine fault
As I went to our garage to boot up our 520i, the message "Enginge fault" popped up on iDrive. The engine didn't run smoothly at all. It sounded more like some simple boat than a sophisticated BMW. According to the dealer something could be wrong with a coil, however, they were at best not able to take a look at it until monday morning.
Has anyone experienced anything similar?
I only had 9500km on my vehicle.
Gents, I hope this does not lead u astray. May not fit your engine and or build dates. And as already stated - coils
SI B 11 05 05
Engine June 2005
Technical Service
This Service Information bulletin supersedes S.I. B11 05 05 dated June 2005.
designates changes to this revision
SUBJECT
N52 Engine Runs Poorly with Camshaft Sensor and VANOS Faults
MODEL
E60, E90 with the N52 engine produced from 3/05 through 6/05.
SITUATION
Vehicles equipped with the N52 engine may be difficult to start, run rough and have the "Service Engine Soon" light is illuminated.
Any of the following camshaft sensor or VANOS faults, as well as various misfire faults, may be stored in the MSV70 module.
2A9A
Cam sensor, inlet signal ? signal invalid for synchronization
2A98
Crankshaft-inlet camshaft, correlation- Value outside reference range
2A82
VANOS intake- stiff, jammed mechanically
2A9B
Cam sensor, exhaust signal ? signal invalid for synchronization
2A99
Crankshaft- exhaust camshaft, correlation- Value outside reference range
2A87
VANOS exhaust- stiff, jammed mechanically
CAUSE
VANOS solenoid valve is jammed or sticking.
CORRECTION
On a customer complaint basis only, perform the diagnosis and repair procedure as described below.
PROCEDURE
Remove the VANOS solenoid, intake or exhaust depending on the fault codes stored, and using shop air, gently blow out any visible particles and reinstall.
It is no longer necessary to replace the VANOS solenoid for these faults.
Reprogram the vehicle using CIP17.01 (Target data Status E89x-05-06-510), or higher for the E90 and Target data Status E060-05-06-500, or higher for the E60.
The modified MSV70 DME data contains additional VANOS solenoid activation logic to flush out any foreign particles.
WARRANTY
For the appropriate labor operations, please refer to the KSD system.
or
SI B12 04 05
Engine Electrical Systems August 2005
Technical Service
This Service Information bulletin supersedes S.I. B12 04 05 June 2005
SUBJECT
Check Engine Lamp Illuminated and/or Vehicle Overheats
MODEL
E90 (3 Series) All Models, E60 (5 Series) All Models Equipped With N52 Engine.
SITUATION
The customer complains the Check Engine lamp is illuminated and/or the vehicle overheated. One or more of the following fault codes is stored in the DME.
FC 2E81 Electric coolant pump, speed deviation, speed outside the tolerance
FC 2E82 Electric coolant pump cutoff, over-current
FC 2E83 Electric coolant pump, power-reduced operation, dry run
FC 2E84 Electric coolant pump, communication
FC 2E85 Electric coolant pump, communication, no voltage at emergency operation input of pump
CAUSE
One the following can be the cause:
Insufficient Power Supply
Insufficient Grounding
BSD Signal not present
Defective Electric Coolant Water Pump
PROCEDURE
Measure the following at connector X6035 on the Electric Coolant Water Pump
Pin 1 (fuse F02) and Pin 4 Ground (X6455) = 12 volts
Pin 2 (fuse F09) and Pin 4 Ground (X6455) = 12 volts
Pin 3 BSD Signal (DME Pin 26) and Pin 4 ground (X6455) = 7.5 ?8.5 volts
If any of the above measurements are incorrect when tested, continue troubleshooting using the DIS Plus or GT1 to determine the source of problem.
If all of the above measurements are correct proceed to step 2.
Note: All measurements should be performed with battery charger connected to the vehicle.
Replace the Electric Coolant Water Pump (PN 11 51 7 546 994) in accordance with Repair Instruction RA 11 51 000.
After performing any service work requiring draining of the coolant. The system must be bled to ensure that there are no air pockets present. The system can be bled using the DISplus/GT-1 or by following a special procedure. To bleed the system follow the procedure described below.
Bleeding (Venting) Cooling System
Fill system with coolant via the expansion tank (AG
. Top up coolant level to lower edge of expansion tank.
Close expansion tank.
Switch on ignition.
Set heating to maximum (temperature); switch on blower (lowest stage).
Press accelerator pedal module to floor for at least 10 seconds. The engine must NOT be started.
Bleeding via EWP takes approximately 12 minutes. Then check coolant level in expansion tank, top up to MAX marking if necessary.
Check cooling circuit and drain plugs for leaks.
If the procedure needs to be repeated several times, allow DME to completely de-energize (remove ignition key for app. 3 minutes) and then repeat procedure as from item 3.
Note: Always connect a battery charger while performing the bleeding process.
PARTS INFORMATION
Part Number
Description
Quantity
11 51 7 546 994
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Refer to KSD for proper defect code and labor allowance for work performed.
or
SI B 12 03 06
Engine Electrical Systems February 2006
Technical Service
This Service Information bulletin supersedes S.I. B12 10 04 dated December 2004
SUBJECT
Loss of Power or Intermittent Crank, No Start Situation
MODEL
E60 525i, 530i (5 Series) equipped with M54 engine
SITUATION
Customer complains the vehicle will intermittently hesitate or intermittently exhibits a crank, no start situation.
CAUSE
A voltage drop occurs between the Car Access System connector X10318, pin 7 and the Fuel Injector Relay connector X6327, pin 8 caused by an internally shorted Oil Condition Sensor (OEZS) located in the lower section of the oil sump. This condition is accompanied by the following fault codes being stored:
CAS FC A0C0 Terminal 15 output 3, signal fault or value above threshold
DME FC 27C3 Thermal oil level sensor signal dropped
PROCEDURE
Select "Control Unit Functions"
Select "Diagnosis Requests"
Select "Terminals"
Select "Voltage terminal 15-1", "Voltage terminal 15-2" and "Voltage terminal 15-3" in the far right column
Select "Display"
If the display does not indicate battery voltage for "Voltage terminal 15-3" then disconnect the Oil Condition Sensor connector X6254 and measure the voltage with the ignition switch turned to the Terminal 15 position. The voltage drop should be no longer present. Attempt to start the vehicle. If the vehicle starts replace the Oil Condition Sensor and install the Power Supply Retrofit Harness (PN 12 51 4 512 589) according to the installation instructions attached to this Service Information Bulletin.
PARTS INFORMATION
Part Number
Description
Quantity
12 51 4 512 589
Defect Code
12 61 91 12 00
Main Work:
Labor Operation:
00 55 189
Installing Power Supply Retrofit Harness and
Replacement of Oil Condition Sensor
Labor Allowance:
21
+Associated Work:
Labor Operation:
00 55 758
Labor Allowance:
19
Note: The following explanations will spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment.
SI B 11 05 05
Engine June 2005
Technical Service
SUBJECT
MODEL
SITUATION
2A9A
2A98
2A82
2A9B
2A99
2A87
CAUSE
CORRECTION
PROCEDURE
WARRANTY
or
SI B12 04 05
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
![Cool](https://5series.net/forums/images/smilies/imported/cool.gif)
Switch on ignition.
PARTS INFORMATION
Part Number
Description
Quantity
11 51 7 546 994
or
SI B 12 03 06
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
Select "Terminals"
Select "Display"
PARTS INFORMATION
Part Number
Description
Quantity
12 51 4 512 589
Defect Code
12 61 91 12 00
Main Work:
Labor Operation:
00 55 189
Labor Allowance:
21
+Associated Work:
Labor Operation:
00 55 758
Labor Allowance:
19
Main Work:
OR
+Associated Work:
