Engine coolant service , plz help..
Old Oct 12, 2010 | 06:52 AM
vsark's Avatar
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish. Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
Does coolant have a shelf life?
I have a large can of BMW Coolant I bought 3 years ago for top-ups. Still have a lot left. I dont see any expiry date on it though.
Old Oct 12, 2010 | 11:04 AM
ivan545's Avatar
I have 96,000 miles on my car and my water pump just went out the other day had it replaced the same time with thermostat so it can break, i would say do the flush it will help. Also check your hoses make sure you do not see any leaks anywhere.
Old Oct 13, 2010 | 07:56 PM
mels545's Avatar
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up! 04 545i all the goodies INCLUDING HEADACHES!
Originally Posted by Diamond
ya its not supposed to be clear. SOmeone dumped way too much water in your tank.
Also you cannot open your resevoir and close it without doing a bleed of the coolant system
If this is true why doesn't the owners manual state this when it explanes how to check the coolent level?
Old Oct 13, 2010 | 11:39 PM
m///power's Avatar
Also you cannot open your resevoir and close it without doing a bleed of the coolant system]
I have opened it to check my coolant level a few times while the car was cold and never had any problems.
Old Oct 13, 2010 | 11:40 PM
m///power's Avatar
Old Oct 14, 2010 | 12:33 AM
Diamond's Avatar
Banned
Well clearly you dont "know" you have a problem until its too late-the problem is smalll small air pockets creating hot spots where coolant is not reaching adequatly--over many miles the engine warps or is damaged and the block/head etc is severely damaged. So its not something youll notice until down the line. Its not some secret or my special way-do some reading and use some common sense. If you want to wreck an engine go for it--its only a 523 anyway--you could replace that old engine for 1k
Old Nov 24, 2010 | 11:36 AM
m///power's Avatar
Info was helpful and thanks for making me feel so good about my car. Will always love my E60
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
thesalboy
Apr 8, 2015 09:13 AM
Stranger12
Apr 5, 2015 10:42 AM
fmusbmw
Bluetooth & Cell Phone Forum
May 14, 2004 11:41 PM
fmusbmw
Apr 11, 2004 04:13 PM
