Engine chatter...
I have an 04 545 and i am curious if anyone else notices some engine chatter during first start up for the day? Once the car is warmed up it goes away and i do not notice again during additional start ups that same day. I have a few thoughts on this but wonder if anyone else has this same issue. It sort of sounds like lifter chatter like you would find on an old pushrod V8 such as a chev smallblock etc when the oil hasn't quite made it up to the lifter valley yet. My other thought was that the pistons are forged(assuming)and as the engine cools overnight the pistons shrink ever so slightly, once start up comes in the AM they make a bit of noise untill the heat swells them up once again. It does seem that once the engine is warm it all goes away. Thoughts? Thanks in advance.
Regards
Barry
Originally Posted by Calgary545sport' post='465821' date='Sep 4 2007, 10:32 PM
Thanks...but i checked the obvious first; the oil level is fine. I do agree with you though as low oil was my first thought.
Did you read this thread?
http://forums.e60.net/index.php?showtopic=...vetronic+levers
Hopefully its nothing but some early 545s had valvetronic levers that were out of tolerance and need replacement. Yours might fall into the category. I know my car does but its not loud enough where I want them to take apart half my engine to replace the levers just yet.
see post #2 here http://forums.e60.net/index.php?showtopic=...mp;#entry420557
system.
I have an 07 550i sport that does the same thing. Dealer says everything is normal...I claim BS....Ifound a simple fix though. Put the transmisison in sport mode during that early morning start up...and voila, the noise goes away. I dont know why, but it works. Once the car is warmed up, I put it into normal mode.
Try it and let us know if it works.
My Ride: 2015 535D M Sport
My Ride: 2004 545i with 325HP 6 speed Steptronic trans with DVD NAV, Heads Up Display, Logic7 sound system, Rear sunshade, Sport Package....
I had a similar issue with my 04 545.... Check the SIB below which was provided by "billeul" to me.
The SIB concerning the rattling or ticking AC compressor is SIB 641406.
It does apply to your car. You can view it at the address bellow.
http://www.bmwtis.com/tsb/bulletins/...p/B641406g.htm
Hope this helps you out.
