Emissions testing & JB4
Old Jul 6, 2014 | 10:50 PM
jmk's Avatar
jmk
My Ride: 2008 BMW 535i
Default Emissions testing & JB4
Do I need to be in map 0 for emissions testing? They do OBD here in IL.
Also, approximately how many miles do I need to put on the car for all of the sensors to be active? Lets assume I just unplugged my battery or cleared some codes.
Also wanted to add that I have c@tless down pipes!
Old Jul 14, 2014 | 09:52 PM
jmk's Avatar
jmk
Bump! Someone please help. I've been rejected 3 times already - every attempt in map 0. Is this required?
Getting rejected because the following monitors aren't ready:
- catalytic converter eff
- evaporative control system
- secondary air system
- A/C refrigerant
- EGR flow
- heated catalyst
Just pulled the codes off my car:
- 29F3 faulty low fuel pressure sensor
- 2DED power management, standby current control
- 29F4 catless downpipes detected
- 29F5 catless downpipes detected
Any tips/advice would be greatly appreciated. I need to pass emissions by the end of the month. Thanks!
Old Jul 14, 2014 | 10:15 PM
Booyaazaa's Avatar
- A/C refrigerant
- EGR flow
- heated catalyst
If you have auto clear turned on and it clears codes before you drive over 100 miles then your car will not be in ready status. If you have **less DP's then most likely you will need to find a place that sells a dpfix like the bms one. That will actually alter the signal to make your system think you have catted DP's then allowing you car's system to reach ready status. Also you should get your lpfp sensor fix before you take your test agin.
navtool.com
Test Forum
Oct 23, 2017 01:32 PM
PMorganRacing
E39 Discussion
Sep 28, 2015 09:49 AM
EuropeanArtz
Sep 23, 2015 08:21 PM
ucsbwsr
Sep 19, 2015 10:58 AM
e60gg
Sep 3, 2015 05:26 PM
