Electrical Problems
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I had the same problem. If your Idrive is recylcing, there could be an issue.
In my case, I paid the dealer to do a current draw test, and they found most bus errors, the first time around. It ended up being a problem with my CCC drive that was causing the drain.
So make a long story short, I've got a spare AGM battery sitting in storage now.
I have posted my experience on here...
Idrive Gremlin
GL
Idrive Gremlin
GL
You can try few more options - just to be 100% sure, disconnect the battery over night and you will see, if this is battery fault you will not be able to start the car as well, this may help also reset all units but in this case if the problem will be still there than you have to see a dealer.
If you change the battery and you will use the same parameters you don't need to coded, is like connection and disconnection.
But because you depleted the battery couple of time there will be lots of fault in the system - so you should do software update from dealer.
sydmaz
05-16-2015 10:21 AM
am1296
10-07-2003 04:24 AM
