e60 xenon retro fit orig lamps
hi there all, i have a 2005 530d sport with halogens, i have bought 2 xenon headlamps with ballasts attached to the bottom,
1. my first question is what is the other slot on the bottom for? is it a control unit for a adaptive function?
2. what do you need to do to get them to work?
i cant find anything on the net about this mod if it is possible or not worth bothering with. i know lots of people fit hid kits, but i want the original projector look.
3. should the car pass the mot without any probs?
thanks in advance to all, if anyone can shed any light i would be really obliged.....
I did send a message about this, please use Search.
There's a OEM set for both the front and read light clusters.
Also some other spans are available.
so you bought OEM xenon headlamps, or another brand?
if non-OEM, where did you buy them from? brand?
I would recc an OEM retrofit if possible..
have a read thru this thread...
http://forums.e60.net/index.php?showtopic=23296&hl=
hi, they are original bmw lamps,
along with..
http://forums.e60.net/index.php?act=attach...st&id=56825
big thanks mate, that is a BIG help, you are top man!!
i wonder is it possible to use everything as is, but just chage the lamps and have them coded on the existing looms etc.???? if anyone knows that will be great.....
Originally Posted by GENEaTALS' post='738865' date='Dec 5 2008, 09:01 PM
nice, the thread listed above should help...
along with..
along with..
