E60 Won't Strart or Steer
Old Feb 22, 2008 | 12:21 PM
flup3's Avatar
Thumbs down
Hello,
I just bought a BMW 520D 2006 with some damage to the front and back of the car.
Engine has not been hit. Just the bumpers and the lights (front & back)
When I try to start the car, it shows the Airbag Diploid light and the Steering Wheel Locked light (with a little '1' in the middle)
The car does not want to start , nor will the steering wheel unlock
The LCD screen in the middle of the dash stays turned off.
Does anyone know what to do ?
Tips are much appreciated
Thanks
Old Feb 22, 2008 | 02:48 PM
DrLev99's Avatar
Did you check these "minor details" before purchasing?
Old Feb 22, 2008 | 03:31 PM
baadaaboo's Avatar
it is a very complicated car, you better have dealer find out how $ to fix these issues.
Good luck,
Old Feb 22, 2008 | 04:03 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Man, that's crazy. It could be something electronic like the key not properly communicating with the CAS module (do a search) or something mechanical in the steering column or somewhere else.
My bet is the electronic avenue. You really need to get the car to a dealer to be able to figure out what's going on. Either that, or maybe you can find someone else that will buy a car that doesn't start...
Old Feb 22, 2008 | 10:32 PM
madoon's Avatar
My Ride: 2005 525i : Alpine White, Steptronic, Black Interior with Amethyst Leather & Popular Grain Brown, 17" 122-Style Rims, Adaptive Bi-Xenon Headlights, Auto Dimming & Folding Mirrors, Advanced A/C, Sports Steering Wheel, Electrically Adjustable Steering Column, Extended Lighting Package, PDC, Sliding Armrest, Bus Navi, Hi-Fi Sound System (MP3 DVDs), CD Changer, Rear Sunshades.. MODS:M-tech front bumper, Painted Grill, Installed Aux-In, Garage Door Opener (Overhead Compartement), ///M Steering wheel, Wood hand brake trim, Wood gear-shift lever. 35% Tint all around.. Got, ACS Roof Spoiler, but not installed..
you can start by going to any garage that has electonic dignostics equipment check out what error codes the car gives, look them up what they are first to know whats wrong then clear the falt memory. im almost sure that would cause a developement from you current situation...
Old Feb 23, 2008 | 09:55 AM
flup3's Avatar
They did a read out of the board computer and it seems to be the battery cable.
The E60 comes with a battery cable that is packed with explosives.
In the event something happens to the car, the explosive blows up disconnecting the battery.
The strange thing is that the battery cable is in no way disconnected.
Electricity can still pass 100% true it.
Old Feb 23, 2008 | 09:57 AM
dpark79's Avatar
My Ride: 04' 545i - Jet Black, Sport Pkg, Premium Pkg, Cold Weather Pkg
Originally Posted by flup3' post='534657' date='Feb 22 2008, 04:21 PM
Hello,
Thanks
I would never buy a car that's been involved in any accident. my 2?
Old Feb 23, 2008 | 10:05 AM
flup3's Avatar
Thats what I do for a living ... I fix damaged cars....
Old Feb 23, 2008 | 12:11 PM
madoon's Avatar
did you clear the fault memory... if you did and the error came back. then there is no doubt the part was used and has to be replaced.. im not sure which part it is. its suppose to be a joint somewhere near the battery.
as i understand the power cable joint does blow in an event of a big impact. but also as i understand the car will unlock the doors and switch on the hazard lights, (perhaps even call BMW assist.)
i cant remmeber i have to look at my battery tomorow but i think there are two wires connected to the battery a small one and a thick one.. maybe the small one is for those small emergency services..
to help you figure things out this is a link to the battery wirring set parts. maybe you can check them find out where the expolisive are supose to be,
http://www.realoem.com/bmw/showparts.do?mo...hg=61&fg=10
Old Feb 23, 2008 | 01:53 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Exactly. There is still a low-current lead from the postive terminal to some of the car's circuits but clearly the car won't start without the main lead...
