e60 trunk will not open
Old Apr 5, 2018 | 06:45 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default e60 trunk will not open
We have a 2010 e60 with N52k.
The trunk won't open manually with the metal key when inserted into the lock.
The trunk won't open with any of the electronic buttons to release the trunk.
Is there an emergency trunk release?
Old Apr 7, 2018 | 08:52 AM
audiophool's Avatar
My Ride: 535xi
That's extremely odd. Assuming the key turns in the lock? Do you feel any resistance when it does? I've never even tried using the key in the lock as the electrics have always worked.
Yes, there's an emergency pull but it's for if you're trapped in the trunk - not accessible from outside at all. I have fold-down seats but you need to be in the trunk to release them - no "key on the parcel shelf" like some cars.
Old Apr 9, 2018 | 06:49 AM
NoQuarter's Avatar
Engine: N54
Have you ever used the metal key (to know how it works?)
It can be quite hard to turn
Old Apr 15, 2018 | 11:36 PM
eugeneasaur's Avatar
My Ride: 530xi 6sp
got the answer to your problems. try flipping the key upside down before inserting into trunk hole. mine only works in one direction.
TheSell
Sep 24, 2022 03:02 PM
zd1818
40
Dec 4, 2020 02:12 AM
jchris
6 Series Discussion
Apr 9, 2009 11:48 AM
Dalton550
Sep 23, 2008 09:49 PM
530E60NL
Aug 24, 2004 06:10 PM
