E60 Transmission oil flush?
#121
Originally Posted by 968turboS' post='1041631' date='Oct 28 2009, 12:38 AM
I borrowed a friend's VW/Audi diagnostic tool when I did this on my previous A4 (had a ZF 5 speed auto). I watched how the temps increased on the transmission fluid and saw that based on room temp of 70deg F, it took approx 5 mins for fluid to reach fill temp of 40deg C.
To make things easier, I just bought the BMW diagnostic that will allow me to monitor transmission temps among other things. I plan to do a drain and fill this coming weekend. It will be a good time to test the theory on a 6 speed auto. I will post results so other can benefit without needing the tool.
Regards.
Raj
Regards.
Raj
How much was the diagnostic tool, would you recommend it, what make/model is it?
I don't like the idea of put a thermometer in the fill hole whilst the engine is running in case it touches something that's moving.......
#122
Originally Posted by JasonH' post='1041804' date='Oct 28 2009, 04:56 AM
I think either the ZF info or the BMW TIS says approximately 5mins for the E60 too.
If you look at DIY, you will see that there isn't much that moves in that area. Regardless, I agree with you. I don't like the idea of dipping a thermometer either. With my luck, it will drop in and I would have to drop the pan all over, lol.
Raj
#123
My Ride: E60
Engine: N54
I talked to 3 local dealerships in the DC area and they amazingly all said the same thing:
Don't flush the transmission until 100k miles.
I expressed I wanted to keep the car for a long time and BMW's 'lifetime' fluid is really marketing for 100k service through BMW. I said what about conventional wisdom that states to change it around 60,000 miles or never again? They still said I should wait until 100k miles.
Really, flush the transmission at 100k miles?
#124
My Ride: Mini Cooper
so there must be some thing wrong some wer if all 3 say that.
In HK dealer they say no need to change it for life. :thumbsdown:
#125
Just to add, I did a 2nd ATF change. This time, I just drained and topped off. All I could get out was 4.5 liters. So, for people that just want to do a drain and fill, you will only get 50% new fluid by this method.
Regards.
Raj
Regards.
Raj
#126
My Ride: 2004 550i - AS, SP, CWP, Nav, L7, Rear Sunshades, PDC, Comfort Seats
With that being said, if tranny breaks down during warranty period, BMW will replace it for me....
#127
My Ride: 2005 545i SMG
Originally Posted by pinguhk' post='1044992' date='Nov 1 2009, 08:54 PM
why the dealer say flush the transmission at 100k miles, when BMW always say the fluid is for life and not need to change
I think since bmw changed their mind regarding the lifetime fluid is really for 100k, if you have the extended maintenance plan and
you are happen to drive a lot and reaching 100k before the plan expires, BMW must cover transmission flush since the plan is 6yr/100k including
100,000 miles not ends at 99,999 and their *SCHEDULED* maintenance for the transmission is at *100k*
NO?
#128
My Ride: E60
Engine: N54
Originally Posted by uheenada' post='1045331' date='Nov 2 2009, 01:47 PM
I believe BMW updated "lifetime fluid" is for 100k miles like last year or so.
NO?
NO?
I must say I was sooooo suprised when the 3 dealerships in here in DC... Arlington, Sterling, and Fairfax all said the same thing. 100k miles!
Normally when I call these 3 I get 3 different answers. How difficult is it for a clear concise answer... I just want to do the right thing!!!
#129
Originally Posted by brianstash' post='1045341' date='Nov 2 2009, 11:55 AM
Great point! Too bad I'm at 80k miles though! Why is all this information amazingly different!
Seriously, I believe BMW dealers don't want to touch it because there are some stories where if car isn't maintained/never flushed(tranny wise) up to a certain miles, you shouldn't replace it. Because it will stirr up the metal sheds etc and could lead into transmission failure and the dealers don't wanna be responsible for that. But if they say at 100k when the warranty expires, then they will just add a cluase CUSTOMER specifically requested and dealers will not held reponsibility and do the flush.
It's a very stupid thing indeed just like they looking at me like weirdo when I bring my car for an oil change every 5k miles.
#130
Originally Posted by uheenada' post='1045365' date='Nov 2 2009, 01:21 PM
It's easy, drive 20k more before it expires!!!
I guess time will tell .
Regards.
Raj
