E60 Transmission oil flush?
#101
You shouldn't just compare viscosity. The fluid that you put in has to be similar in properties to what's already in there. That is more important than anything else. Pentosin fluid has similar characteristics to the factory Shell fluid. Either of these fluid will work. I have successfully used Mobil1 ATF in cars with ZF, but they were the 5HP design that came with Esso LT71141 fluid or Pensotin VW equivalent. I don't feel comfortable using anything but either Shell, ZF or Pentosin on the 5 though.
Regards.
Raj
Regards.
Raj
#102
Regards.
Raj
Regards.
Raj
What other properties would we need to compare? Color, chemical composition, additives...?
I agree with you Raj, but I am suspect of the marketing hype. Pensotin is made in Germany and is logically used on many european cars (Audi, VW, BMW, Jaguar, Range Rover, etc...). It does not surprise me that it is recommended by BMW and is also very expensive in the US due to its manufacturing origin. Castrol is made here by BP Lubricants and is designed to be integrated with many different types of transmissions, both German and Japanese.
So is it just marketing or is there a difference?
#103
Sorry, I know that doesn't answer your question but I wanted to play it safe on this car.
Raj
#104
My Ride: 04 525i, 04 Dinan M3
Good timing on this thread. I have been noticing my transmission does not feel as smooth and I wanted to change it. I'm at 73k miles.
#106
Originally Posted by 968turboS' post='1035802' date='Oct 19 2009, 12:26 PM
I plan to do this in the next couple of days. I have all the parts. Also plan to do a DIY writeup.
Regards.
Raj
Regards.
Raj
#107
Originally Posted by neoe60' post='1039532' date='Oct 24 2009, 01:27 PM
We'll be waiting anxiously! ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I will get in touch admins.
Raj
#108
Originally Posted by 968turboS' post='1039797' date='Oct 24 2009, 10:09 PM
DIY is all ready to go but the system would not allow me to post something with this many images. Darn!
Raj
Raj
https://5series.net/forums/index.php?showtopic=88123
This is my 1st attempt here, so please provide feedback. i have done plenty of other forums but this is a new crowd
Raj
#110
Originally Posted by turboawd' post='1039819' date='Oct 24 2009, 10:51 PM
itd be nice if someone collected some old fluid and did an oil analysis on it.
Raj
